SOURCE: Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
SOURCE: water level on rinse is
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
SOURCE: i have an admiral washer atw4475xq can you adjust the water level on the rinse cycle
Pulled this together from a couple of Solutions & added some helpful tips I found as I successfully changed the rinse cycle water level!
ATW4475XQ - Admirial Water Saver washer - Adjust Rinse cycle water level
The rinse cycle water level can be adjusted. Unplug the machines power.
You can youtube a video on how to remove the top control panel, its just 2 screws on the back of it,
phillips head. Swing the control panel up, and find something to support it so you have both hands free.
(http://www.youtube.com/watch?v=MYn0_qCFdec)
You'll see a clear plastic tube coming up from the back rear like 3/8 in diameter, to a "T"
connection. The one that goes to the left, thats the wash water level switch it connects to. The one you
can adjust, large, medium, small, from the front of the panel . The other off the T goes to the rinse
water level switch. There is not a knob to adjust it. But if you look at the bottom of the lever
mechanism/cam pickups of both switchs, you will see that they are the same. Rotate the wash load size
(knob on outside of control panel) from small to large, back to small, notice how the mechanism changes?
The rinse water level swtich acts the same way, although it is only a 2 position switch, small and
large. Once you watch the wash level mechanism move from rotating it back and forth a few times, you
should be able to see how to rotate that same mechanism on the rinse switch 1 click. It will click into
place, there are only 2 positions as I said and from the factory its in small, so once it "clicks in"
dont go any further. I did mine with a very small screw driver without removing the rinse switch.
Once you get that hidden switch turned to the other position, put it back together, fire it up and now
your rinse is the large level, all the time.
NOTE: There is a white plunger out of the end of each switch with a screw located in place. Dont mess
with the screw or that plunger. As you adjust the lever mechanism/cam this adjusts the amount of that
plunger sticking out, which changes the pressure pickup for water level.
