My panasonic rear projection tv pt56dlx75 will not turn on. It has turned back on briefly then shuts off. The lamp appears not to be blown. What part could be failing??
    Problem Solver:
  • 9 Answers
Probably a diode. What its doing is going into protective shut down. Check your manual for a schematic.
Posted on Jun 24, 2009
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
47in dlp tv that turns on then shuts back off
The lamp may be bad or a fan has stopped running. Remove your lamp and see if it's shattered or dark and gray in the center. Also your lamp timer could have reached it's limit. check your manual to see how you can reset the timer only if the lamp looks clear.
Jan 29, 2010 | Panasonic PT-47X54 47" Rear Projection...
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not...
I have similar problems. I removed the back panel and use compressed air to blow out all the dust from all the components. Just remember not to blow into the main fan on the right as that is the one cooling the lamp. I don't know for sure if this is the only problem.
Dust built up caused heat built up on the components.
Nov 15, 2009 | Panasonic PT-50DL54 50" Rear Projection...
I just replaced the lamp in my tv and now it shuts
You probably have a defective new lamp. Did you put the lamp door back on?
Aug 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Hdtv rca
You need a new lamp. Your lamp have been blown. You can purchase the lamp from rca or other vendors on the net or you local tv store and you can also install it yourself. The lamp is usually located in the back of the tv on the side of the protruding back. Next time you do install your brand new lamp, when shutting down your tv wait for your fan to shut off before disconnecting the power cord. Doing so will shortened you lamp life.
Dec 28, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Tv shuts off but power light continues to flash
Unit is telling you something is wrong with circuit. LED pilot flashes when malfunction is detected. Power supply shuts unit down to prevent further damage and/or fire. Leave off and seek pro/tech check out
Nov 30, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
