Question about Dometic Rooftop RV Air Conditioner
My son's RV throws Breakers if Hot Water Heater is on with A/C
My son bought a used RV. He has always seemed to have problems with the breakers kicking off (30 AMP System), that was in the winter. Now that it is summer, the breaker for the A/C is kicking off  after about 5 minutes of running. He even turned the water to the GAS mode so it would not use any power.
IT IS HOT HERE IN ALABAMA, ANY HELP WOULD BE APPRECIATED.
  • 79 Answers
Check the condensor on top of the roof, make sure it is clean from lint and dirt, and the fins are not bent. Turn off the power and wash it down with a water hose, then let it dry out restore the power and see if that stops the breaker problem, you could also take the cover off the breaker box, and turn off the a/c breaker and try tightening the screws that hold the power wires to the a/c unit.
Posted on Jun 24, 2009
  • 69 Answers
Well not knowing the year Id say you might want to get new breakers if there already new check the lines for wares and damage.
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
My suburban dsi rv hot water keeps throwing breakers
Appears to be a short in tank circuit probably cause by a water leak in tank. These usually wear a rusty hole in the tank inside the cover and are not seen unless the thermostat covers are taken off. I would remove them and do a visual thoroughly. Anytime a fuse blows or a breaker trips is always a dead short unless you have a bad breaker. I would check those as well for vibrating, chattering noises, and/or smoking. If any of this persist, replace breaker. A melted heat element could trip them, but not usually for it leaves an open circuit instead of a shorted one.
Feb 19, 2013 | Suburban SW10DEM Gas Electric Water Heater...
How do i know when 220 circuit breakers are bad
Always match breaker and wire size:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Feel if breaker is getting warm.
Listen for crackling sound.
Breaker is tripping.
Move wires to another same-size circuit breaker and see if problem continues.
Check watt or amp load on breaker.
For example water heater label shows 4500 watt non-simultaneous.
4500 watts divided by 240 volts = 18.75 amps.
You might think 20 amp breaker was good in this case.
However electricians use 80% safe maximum.
20 amp breaker x 80% safe max = 16 amps.
Water heater is 18.75 amps, so install 30 amp breaker.
30 amp breaker uses 10 gauge wire.
This means wire to breaker will run cool and not get hot, so breaker lasts longer, and there is more efficiency.
Using 80% safe maximum rule protects home, reduces heat wear on breakers and breaker box so everything lasts longer.
Nov 18, 2012 | Dryers
The air condition in my 2006 Lardo 5th wheel keeps throwing the breaker sometime it will run 15 minutes or 4 hours then throw the breaker
You could possibly have a weak set of breakers. If you have access to an amp meter, clamp around on of the wires coming from the breakers so that you can measure the amp draw. If the amp draw of the unit (when running) is lower than the breaker rating, change the breakers.
The other problem could be a stopped up rear coil. This is the part that looks like a small radiator the the hot air blows through on the roof. You will have to take the cover off the unit to see the inside of the coil. Look through the rear fan blade and you will be able to see if the condenser coil is stopped up wit dirt etc. Hope this helps.
Aug 07, 2011 | Dometic Rooftop RV Air Conditioner
Hot water heater keeps throwing breakers and we change them and we have hot water for not even a day and cant afford an electrician
I can help you with tank-type water heater.
The type of heater is unknown: do you have tank-type, or tankless, or boiler?
Open following links to get started. Be patient and read the information, and add a comment with a question and I will answer back.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 23, 2011 | Rheem Water Heaters
Power was shutoff to house at pole all breakers were off.power restored breakers turned on took ashower next day no hot water breaker tripped will not reset water heater reset doesnt work either i have a...
according to your problem, the power was cut to the house; then power was restored and everything went back on that was on except the hot water heater. when you tried to reset the water heater breaker, it wouldn't reset. the hot water heater also won't reset. the problem is not w/the breaker, the problem is w/the hot water heater. you need to buy a new reset for the hot water heater which means a new control unit, since the reset is hooked to the contol unit. this is answered by an electrician w/35 yrs experience. the breaker controls the hot water heater. since the breaker won't reset, the problem lies in the control unit for the hot water unit.
Mar 08, 2011 | Kitchen Ranges
No hot water on electric but burning hot on lp gas,what can my problem be.
Need to confirm hydro to water heater, all switches breakers etc on, and check to make sure switch at back of water heater at connection box on as well. If power to back of water heater, then check for reset in center of ECO on back behind cover. If power going to element ( behind cover as well) then replace element. Be careful when removing cover on back. Shut breaker off at main panel until you can get cover off and ready to test voltage.
Feb 26, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I just put in 2 new breakers in mybreaker box mystove works but not my hot water heater. Imay havegotten my breakers mixed up does a hot water heater take a 15 or 30 size breaker????
They both take a 30Amp breaker or fuse as they are fed off of the 220V. They both have demands above 20Amps when they are fully used. in particular the hot water heater has a fast recovery mode in which both cal rods are heating at the same time.
Feb 12, 2011 | Water Heaters
JUST PURCHASED A RELIENCE 602 ELECTRIC HOT WATER HEATER 50 GALLONS TO INSTALL IN MY HOME WHAT GAUGE WIRE AND BREAKER DO I NEED TO INSTALL
The hot water heater should come with an amperage rating on it.
They vary from 30 to 40 amps, and then 10 or 8 gauge wire.
(All hot water heaters are 220 volt.)
I believe the 602 uses a 4500 watt element.
Divide 4500 by 220, and you get about 20 amps.
If you want to be on the safe side, you go with the heavier wire, 8 gauge, and then go with the smaller breaker that is more easily tripped, 30 amps. That way you can switch to a 40 amp breaker in the future, without having to change the wiring. The goal is to always make sure the wire is rated higher than the breaker. You want you breaker to trip before your wire melts.
But technically a 30 amp breaker and 10 gauge wire would be fine for this heater.
And since it is 220 volt, you will always use a double breaker.
That is because 220 volt appliances don't use a ground, but instead use the potential between to power wires that are 180 degrees out of phase. AC always does a sine wave, and the 2 power leads coming into the house are always out of phase. When one is 110 volts up, the other is down. So the total between them is 220 volts. And the way they intentionally zigzag the breaker box, 2 breakers next to each other always are on opposite power lines.
If you have any doubts at all about 220 and water heater wiring, please ask again. Wiring is not hard, but you have to understand what you are doing, or else you can cause serious consequences.
For example, if you use wire nuts or wrap wire around a screw, you need to always turn them clockwise, so they pull the wire when tightened.
You also always need to ground the chassis with a green safety wire.
Since a 220 hot water heater uses 2 power wires and a safety ground, the white wire should be striped with a permanent marker, so that it is not confused with the white neutral wire of a 110 volt appliance.
Aug 19, 2010 | RELIANCE ELECTRIC WATER HEATER
A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
May 15, 2010 | Coleman Mach III Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
162 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
