Question about Initial DTV-171 17 in. TV/DVD Combo
Tv remote code
Do you have a remote code that will work with direct tv
Re: tv remote code - Initial DTV-171 17 in. TV/DVD Combo Combination Televisions
Try 11990, 11991
Posted on Nov 18, 2008
Re: tv remote code
Who knows the remote codes for Direct TV remotes??
Posted on Dec 31, 2007
0 characters
3 Points
No. I need a code for my TV or help getting it working with Direct TV
No. You have to program the directv remote to work with your tv. You may have to select the tv button.
Oct 16, 2015 | Apex Digital GT2015DV 20 in. TV/DVD Combo
I lost my remoe and manuel.I went to walmarts and bought a universal remote taht say its compatable with Broksonic..I will not work..want turn tv on or off? any sugestions?
U should turn on the tv ON manually by the tv power button to get the tv ON and used all the codes that was provided by the universal remote user manual for the ur tv brand Broksonic.U must follow the directions carefully and enter each codes correctly,the correct universal codes for tv is enter,ur tv will able to work by the tv universal remote power button will able to turn the tv off/on of the tv set.If none of the tv universal codes that was provided by the universal remote user manaul for ur tv brand Broksonic don't work.Just return the thing to Walmart and get ur money back.Try website like to buy the tv original remote,than 100% will work for ur tv set.
Aug 17, 2011 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
I have an apex ld3249 tv with remote. The remote died a couple of days ago. I have had the tv for 6 weeks. A universal remote will not work. A new Apex remote is $60. Is this going to be an ongoing problem...
There is no warrantee for the remote control for any company's set. A universal remote should work with your Apex tv. I'll give you the model and codes for the remote that suit to your apex TV. Buy one and match it to your TV.
PHILIPS [CL 034] universal remote control.
Codes are:-
0023 0223 0123 0741
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Feb 15, 2011 | Apex Digital Combination Televisions
Still looking for the remote codes for our HCT TV\ r\n MODEL#HLD-22HCB
you won't find one...had my hct tv for more than 2 tv cannot program remote....i just used both remotes
Oct 09, 2010 | Combination Televisions
Got a jumbo remote and lost my codes got a sylvania tv and need codes
Look in the directions for the remote; it should tell you how to have the TV scan for the right code. Or the directions may have a code for you to enter for your particular TV, it depends. Otherwise, go to the web site for the remote. You will need your TV make and model number. Got that?
Jun 11, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
No code available to program my SV2000 tv/dvd combo
The manufacturer for this television is Sylvania, the standard codes for TV/DVD combos will work just fine.
Apr 02, 2009 | Combination Televisions
Need remote code for direct tv connection
my Emerson EWC1303 13in. TV/VCR combo Remote stopped working. any suggestions?
Oct 16, 2008 | Emerson EWC1303 13 in. TV/VCR Combo
How to connect a Time warner cable remote to the tv
I made mine work by using programing the vcr button as opposed to the tv.
Aug 21, 2008 | Sylvania 6520FDE 20 in. TV/DVD Combo
Need Philips Universal Remote Codes for a Sanyo TV
Hi Pamr
Try the Phillips website >HERE< which links to their Universal Remote support centre. Unfortunately you haven't given the details of your actual remote but you should be able to find it and download a manual or email them direct.
Sanyo TVs use all these codes:
0506, 0311, 0612, 0002,
0428, 0802, 0412, 0619,
0208, 0157, 0292, 0036,
0011, 0370, 0072, 0216,
0217, 0104, 0045, 0009,
0163, 0037,
Sorry there are so many, but one should work.
Best wishes...
Mar 23, 2008 | Combination Televisions
Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Nov 08, 2007 | Toshiba 14DLV75 14 in. TV/DVD Combo
Initial DTV-171 17 in. TV/DVD Combo Logo
164 people viewed this question
Top Initial Combination Televisions Experts
Steven Wander
Steven Wander
Jim Goldsmith
Jim Goldsmith
Are you an Initial Combination Television Expert? Answer questions, earn points and help others
