Question about Refrigerators
I have a very old Whirlpool refrigerator which I just changed the thermostat because of either too cold or too warm.It wasn't turning on or off unless I tapped it. It was working fine for awhile but now I noticed the inside back metal panel where the thermostat wire goes behind is frozen and the refrigerator is 50o or warmer. I have the thermostat set at the highest setting of 5 and it still seems warm according to the refrigertator thermometer. The wire or coil coming off the thermostat is in a plastic sleeve. Should I remove this sleeve or try placing the wire /coil in front of the metal panel? Thanks for any help- Al
  • alu9002 Jul 01, 2009
    I figured it out myself
    President:
  • 1,136 Answers
Hi, Are you seeing the ice building up in the fresh food section or in the freezer section?
Are you seeing solid ice or is it frosty? Please let me know so I can assist you further.
Vic
Posted on Jun 24, 2009
My Whirlpool Refrigerator/Freezer Model #GR2FHTXVQ00 or GR2FHTXVO00 is not keeping food cold. Food is spoiling. Freezer is cold but Refrigerator is warm.
With signs of freezing up in freezer area that would indicate a problem with the defrost components. The most likely reason would be a defrost control board. 2304093 Defrost Control Board
Here is a link to a parts manual for your model=> GR2FHTXVQ00.pdf(1101.27 KB) Look on page 3 and part location 4 That is the=> 2304093 Defrost Control BoardThe next possible parts are the 2314157 Defrost Heater Assembly found as item location 4 on page 9 of the PDF. It may be a good idea to change the defrost thermostat=> 2321800 Defrost Thermostat found on page 3 with item location 28. If you have questions please let me know, Thanks John TrippAppliance 911
Contact Me Here
Sep 23, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
The freezer section is not cold enough and the fridge section is totally warm. my fridge model is WBM35 IX. called the technician (not from whirlpool though because the agent is no longer available in...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Whirlpool Refrigerators
Our Whirlpool Gold GB22DK model is not working...the freezer works fine, but the refrigerator is warm and not working. What part would I need?
check the thermostat is working by turning the tem down it should drop the tem if its dont change the thermostat
Aug 22, 2010 | Whirlpool Refrigerators
Side by side, freezer very cold, frige warm
Any ice buildup is due to one of 2 problems. Either the defrost circuit is not working properlyor the drain hole where the defrosted water drains down to the underneath pan is clogged. I once found a spider's nest in the drain of a refrig that was in a seasonal house after the winter shutdown.
Very common is a defective (open) defrost thermostat, or a bad defrost timer. But for a unit only 5 yrs old I'd start with the drain hole. BE SURE YOU GET ALL THE ICE OUT. Use hot water, hairdryer etc, so water flows freely to drain pan
Aug 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Turns off won't turn back on unless you move thermostat
Sounds like a defective cold control ( off/on thermostat).
They will tend to stick in the off position. Your moving the knod unsticks it.
May 24, 2009 | Whirlpool ES5FHAXS Side by Side...
My 3 yr old whirlpool fridge has been constantly running for the last few days. The temps in the fridge and freezer portions are running high and the sides of the fridge are warm to the touch. What they...
" The refrigerator never cycles offThe thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
From repairclinic"
Aug 29, 2008 | Refrigerators
Refrigerators Logo
318 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
