It was installed a year ago, and was loose to the touch. It got wobblier with time, eventually it began to leak.
SOURCE: hansgrohe bathroom faucet handle is loose. how do
remove the cover in the center of the handle and you should see if it is a phillips screw driver or some other fastener type.
SOURCE: Hansgrohe 06566860 Metro Single Hole Kitchen Faucet
make sure the hose under the sink, ( the one that goes to the faucet) has not gotten twisted around anything. sounds like it is losing pressure. it takes steady pressure for the stream to maintain that "needle" spray.
SOURCE: I just installed a Hansgrohe Metro E kitchen
I had same problem. Wrap the threads with teflon tape 2-3 times. Use a wrench and pair of channel locks to tighten the connection.
SOURCE: hansgrohe single handle bathroom faucet handle is
Look under the lever for an allen screw.
--W/D--
