Question about HP Compaq Presario C304NR Notebook
On this same laptop, my Presario C501, I want to know what the maximum amount of RAM I can buy and install to make it the best it can be. Right now it is, as purchased, and it has a Celron M processor with I believe, 1G. I have looked for these specs and have had no luck, any help would be appreciated!
  • gregbronn Jun 26, 2009
    Thanks for the info, I am working on getting the xp install disc right now, and I will get the ram after if it needs it. Thanks again!
    President:
  • 627 Answers
Usually like this:
Details of - COMPAQ PRESARIO Laptop - Celeron 1.7 Ghz - C501
Main Features :
  • Intel Celeron- M 420 (1.73 GHz)
  • Intel 940GML Chipset
  • 1 MB L2 Cache
  • 256MB DDR2
  • 80 GB HDD
  • 24X CDRW/DVD Combo drive
  • 15.4" Widescreen WXGA TFT BrightView
  • Altec Lansing Stereo Speakers
  • 56K Modem
  • Integrated Wireless LAN 802.11 b/g
  • LiIon Battery
  • TouchPad
  • S-Video TV Out
  • 2 USB 2.0
You cand put extra memory until 2 GB RAM but i see no use of it.
1GB RAM work excellent under Winxp
Also, you can get a better hard drive (160 GB).
Posted on Jun 25, 2009
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Can I upgrade the ram on the acer aspire 5630 notebook?
Yes, you can.
You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Nov 25, 2010 | Acer Aspire 5630 Notebook
Hi i want to know if my laptop is with ddr 2or ddr 3,it is 1gb presaroi cq 60
The details about your laptop's ram,
Maximum = 4Gb
Technology= DDR2 SDRAM
Form Factor =SO DIMM 200-Pin
So, ram installed on your laptop is DDR2. If you need/want to upgrade, you have to look for and buy DDR2 type ram.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Compaq Presario CQ60-220US PC Laptop
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
After I upgraded RAM from 512 MB to 2 G, my computer can not resume from stand by mode.
1.Do you know what the Maximum TOTAL Amount is for your ram?
2.Do you know what the Maximum Amount is for EACH ram slot?
3.What is the computer manufacturers name, model name, and model number?
(Example: Compaq Presario SR1110NX.
Compaq: Computer manufacturers name
Presario: Model Name
SR1110NX: Model Number
(Not trying to insult your intelligence with Number 3 above)
Reason for asking Number 3?
Let's take an example. Let's say your computer has a Maximum Total Amount for ram memory, that is 2GB.
EACH ram slot's Maximum Amount is 1GB, and you have two ram slots.
If you install a single stick of 2GB ram in Slot 1, chances are it isn't going to work.
If I know what computer you're referring to here, then I can give more of an exacting solution.
Sep 25, 2009 | Epson Stylus CX4800 All-In-One InkJet...
My laptop was need to activation
A Compaq Presario 700US doesn't have the hardware to run Vista.
1.Processor: AMD Duron processor that operates at 900MHz
2.Ram Memory: 256MB of PC133 ram memory, (SDR Sdram that operates at 133MHz)
3.Graphics: VIA S3 Integrated graphics chip
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255264&lc=en&dlc=en&cc=us&lang=en&product=95525
Your laptop will run Windows XP, but I would advise upping the ram memory amount to the maximum, for the best Windows XP experience. That would be 384MB of ram memory.
Change to Windows XP? Sure. Just buy the full installation disk of Windows XP. (About $95 US online)
Be sure to go into your BIOS Setup, and in Boot Options set the first boot device to CDROM.
Whoever tried to put Windows Vista on that laptop, didn't know what they were doing. That laptop Will Not run it!
Sep 01, 2009 | Compaq Presario 700 470024-192 Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Not Enough Memory
Actually, according to www.crucial.com, the maximum amount you can have is 384mb, with 128mb in each slot.
The info can be seen here: http://crucial.com/store/listparts.aspx?model=Presario%205150
Mar 23, 2009 | Compaq Presario 5000 PC Desktop
Trying to price/find ram upgrade for compaq presario m2000
You can go to the manufacturer website and check on the product model specifications to show you the correct limits. For example, if you have a hp laptop, go to www.hp.com and enter your product model in the search. then look for product specification page and you should be able to verify the memory limits
Mar 10, 2009 | Computers & Internet
HP Compaq Presario C304NR Notebook Logo
258 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
