My system is running but not blowing cold air
I have been told that because the coils on the inside unit are not getting cold while the system is running, there must be a leak which caused the release of the coolant. My unit is 15 years old. Can it be repaired easily if a leak,releasing coolant, is the problem? Or would it be more cost efficient to replace the unit now?
  • 24 Answers
It depends where the leak is. If its in the coils, you have to replace it. If the leak is easy to get to it would be cheaper just to fix it. So it all depends where the leak is. but 15 years is kind of old for a unit.
Posted on Jun 24, 2009
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
Ac freezing
for a homeowner the first thing to check is the filter. also make sure the fan inside is running. once the coil freezes it does make it more difficult to push air so coil must thaw. don't continue to run unit if you see ice, you are only harming the system. if checks are good you likely have refrigerant issues and need a technician
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 06, 2018 | Goldstar WG5000 Air Conditioner
Exterior CKL49-1A AC Unit not blowing cold air
Why you need to change evaporator coil when condenser fan not working ,also why would you even charge unit with looking for leak.
Maybe the evaporator coil is leaking and when you recharge it it work for couple of days now unit is empty again .
If unit have low pressure switch then outside unit would shut off.
Jan 05, 2018 | Coleman Heating & Cooling
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
SHARP AE-A244J no cold air
Your possible problem could be something as simple as cleaning your coils. The outside coil could be possibly clogged with dirt or the worst is cottonwood if they exist in your area, this depends on how long the unit has been installed, be sure to unplug-shut down any & all electricty to the unit, spray coils with a good dirt solvent, 409 works good for this, hose the coil with as high a pressure as possible, let dry for at least 1 hour before connect electricty. Inside coils get clogged also, with running unit without filter, or using for a long period on time. Sometimes these are hard to get to, although you should be able to see them, if not call a pro. Another prob. could be low on freon, another job for a pro, this means you have a leak in the system.
Lee
Dec 16, 2009 | Heating & Cooling
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
UNIT WONT BLOW COLD AIR
The A-Coil is pluged up. you need some foamagator. it will foam up and clean your coils. don't forget to clean the outside coils also. but the one that is stopping the air from blowing is inside by the furnace. Hope this was helpfull
Saw
Aug 09, 2009 | Heating & Cooling
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
