Question about Verizon Communications enV2 Cellular Phone
Front keypad won't work.
I have had my env2 for about 4 months now and whenever I open up the phone to use the full keyboard and then close it again, most of the keys on the front won't work. The keys that won't work are: the ok, the send, the up arrow, the clear, the music, 4-6, 7-9, and star, 0, and the pound key. If you could help me I would be soo happy.
    Problem Solver:
  • 15 Answers
Sounds like it's still under warranty, take it in...
Posted on Aug 10, 2009
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
Some buttons on my HTC keypad aren't working
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Aug 08, 2012 | HTC Amaze 4G
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Doro PhoneEasy 410 some buttons won't work on keypad
It maybe a flex problem or keyboard problem. The reason why I said it maybe a flex problem is because flip phones are fond of having flex problems because of the constant open and close of the flip. It makes the flex wear/worn out.
And it maybe a mere disconnection.
Which ever the case maybe, the phone needs to be disassembled in order to check/know what's wrong.
Regards.
Jan 25, 2012 | Doro PhoneEasy 410 Cell Phone
When closing the keypad
100% Promblem with your Main cable. you have to  replace it.
Jul 19, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Cell phone only works when open to Qwerty Keyboard, It freezes up
if u got your g1 less than 12 months ago and didn't choose internet when u first got your phone there is a manufacturers warranty that comes with your phone from when u got it. Call Asurion or go to
http://www.asurion.com/contact.html
Jan 06, 2009 | HTC G1
Phone works for about a minute then goes black and dies
The keyboard cable is worn or broken, take it to a service center for replacement. The keyboard cable has a small magnetic switch that detects when the phone cover is open or closed. If the keyboard isn't working and the internal screen is blank, the phone detects that the cover was closed.
May 02, 2008 | Motorola Mobility RAZR V3
My keypad does not work on my razor
My phone (in a cotton phone bag) was very slightly damped by a spilled drink about 4 months ago. The keyboard immediately stopped working (only power button works). My friend told me to blow dry it, so I tried and it worked.
Just today, my keyboard stopped working again even though there was no further water damage (at least not to my knowledge), I used the blower dryer trick again. and it worked again. So ... you can give it a try.
Nov 02, 2007 | Motorola Mobility RAZR V3
Motorola V3 Razr Keyboard will not light up
Are you getting sounds from the dial pad? It should default to momentary lighting, but it can be adjusted for longer time. It sounds faulty, did you purchase a refurb?
Oct 31, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Verizon Communications enV2 Cellular Phone Logo
396 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
