Question about Fisher and Paykel Washing Machines
How do you change out the two bearings on the GW-708U? The Seal was leaking and has corroded the top bearing.
  • 1 more comment
  • peter_woodwa Jun 24, 2009
    Thanks for the fast response but this doesn't help. The description and sample drawing look nothing like what I have. The F&P has no pulleys,belts or gearbox, relies on a motor with the stator mounted to the spindle and the 'rotor' on the outside of the stator. The suspended outer drum of which the stator is bolted at the bottom, has a hollow plastic core where at the bottom appears to be an embended aluminium sleave which the stator is bolted. The two bearings are within this plastic core and aluminium sleeve, the spindle is removed. I cannot get a bearing puller within the core. To hammer out the bearings from inside to outside (bottom) of the plactic core would damage the aluminium sleeve.
    There is no right side bearing. The GW708U is top loading washer so the bearings are mounted at the base of the outside bowl where the spindle goes through the bowl.
    After removing the outer bowl from the washer, I was able to remove the seal from inside of the outer bowl. Then with the bowl upside down I was able to 'knock' out the bearing(the problem child) past where the seal was located. Replaced this bearing and the seal and she now works beaut. Thankyou for your follow up.
  • 2,071 Answers
Changing the bearings on this appliance is a straightforward job. Unfortunately it's also a complete strip down of the appliance. The whole drum assembly has to come out of the appliance and be broken down to it's component parts, then the bearings and bearing seal have to be pulled from the rear half of the outer tub and the new ones pressed in. The front of the appliance comes off to facilitate removal of the tub assembly. You have to work your way through this methodically and make careful notes of what part goes where and also of the wiring. I suggest using a digital camera to take photographs as you go along. To replace you have to take out inner bowl.This how to remove the inner bowl. You must lift lid and then remove Two Screws From The Front Hob (Theres Plastic caps over Screws) Hob Lifts Back and Remove Agitator .Then unclip BIAS spring from front left suspension Rod. Remove Bowl Cover (Plastic ring) Bowl Lifts Out You can remove 3 Spline Drive Screws (IE Drive Spline is Plastic Piece Under Agitator) They generally come out with not much fuss. Just use a bit of back & forth up & down movement .You have to take out Outer Bowl complete with motor Pump etc Attached. To get that out you have to remove suspension & drain hose clips Etc. Once you?ve got the whole outer bowl out turn him upside down & remove Motor & stator Etc. Then you can get to shaft seals & bearings. Just click below smple in how to fit the bearings.. http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/how-to-fit-a-bearing-in-a-washing-machine/ Hope it may helps: Regards: VOTIT
Posted on Jun 24, 2009
    President:
  • 1,197 Answers
If you are new to this, you will have to give your selfapproximately 8 hours. In real time this is 2 days of anyones time.We engineers can do this job in about 2 hours or so but this isnot a race as we only want to do this the once.
I’m assuming you already have a decent tool kit otherwise youwouldn’t be attempting this washing machine bearing change. A decentscrewdriver set, a few open ended spanners - 10mm, 13mm, 17mm, 19mm -and a decent hammer, a big one, no lets make that a really big one. Asan apprentice engineer, brute force and ignorance was my biggest assetand it still carries to this day so don’t be afraid to use a big hammer.. but use it wisely... coz unlike apprentice engineers ur working on ur machine......
Power off, remove covers. Disconnect drive belt, remove drive pulley.Remove heater, thermostat and pressure switch. Check if drum splits atfront, rear or the middle. If at front or middle, drum will prob. needremoval from machine. This involves dismantling the suspension anddamping system and removal of door seal and concrete weights. Undo thedrum fixing system either a clamping ring or a series of peripheralbolts and split the drum.
If the drum splits at the rear, removal from machine prob. notrequired. Remove the clamping system and pull off the rear plate. Sealand bearings will come away with the plate.
Seal needs to be dug out with a suitable lever and the old bearingshammered out with a punch from opposing sides of the backplate.Refitting is as they say a reversal of the above process.
Below I have included a drawing of a typical washing machine drum. Thiswill help you identify the parts and aid your attempt and dismantlingthe washing machine.
for a better display of the image....... clik the following link.......
http://www.keepingupappliances.com/repair-help/images/WMA32.gif
u can order the bearings at the below site
https://spares.bigwarehouse.com.au/index.php?cPath=64658_64721_65595
if u feel i ve spent my time for ur problem.... kindly rate my service....
good luck
  • SAM JAYANTH CHANDRASEKAR
    The drum bearings on these units are located on
    the right side about in the middle. If you start a load and notice the
    noise is coming from that area, well your going to need a new bearing
    kit. If the source of the noise seems to be elsewhere, then it's time
    to take the unit apart and do some investigation. But to install a new
    bearing, we simply open the lid and remove the bearing cover located on
    the right side middle. Underneath the cover you will find the bushing,
    bushing keeper, and shaft. The new kit will come with all three
    replacement parts, so take the old ones out and put the new ones in.
    good luck....
How to resolve a noisy bearing
the bearings only become noisy if water has leaked past the main seal and into them in which case if its a top loader you will need to replace both bearings the main seal and shaft, it can be quite costly. if its a front loader you will need the main seal and both bearings and will cost twice as much as the top loader as it takes quite alot longer to do
Oct 03, 2014 | Fisher and Paykel Washing Machines
Oil leak coming from the top right hand side of the motor by the cam shaft talked to dealer and it got me no where need to know what that part is and what is does so i can stop the leak
could be the cam cover case, or the cam shaft bearing seal leaking.
cam cover gasket easy change. cam shaft bearing seal, not really a bearing its shims. that involves removing the timing belt and taking out the cams and replacing the shims on all of them best to do all as when you start moving stuff you can put a crack in the old ones when refitting.
Oct 08, 2013 | 2006 Volkswagen Passat
We have an Ignis awf 595 washer dryer. The machine is now beyond economical repair due to the drum shearing off its bearings. What would cause this to happen.
It would be caused by a corroded and then seized up drum bearing from a water seal leak, detergent is very corrosive and very quickly ruins the drum bearings.
Feb 06, 2012 | Maytag Washing Machines
Hi, My booster pump for my pool is very loud. It is a Pentair model number LA01n. It has gotten louder over a period of about 2-3 months. It has a small leak in the front seal and I had the seal...
YOUR BEST BET IS TO COMPARE MOTOR REPLACEMENT TO AN ENTIRE PUMP REPLACEMENT
MORE THAT LIKELY ITS PROBABLY NOT A GREAT INVESTMENT TO JUST DO A MOTOR ON A BOOSTER PUMP
YOUR MOTOR IS NOISE IS COMING FROM BEARINGS INSIDE THAT ARE GETTING WORSE AND WORSE
NOW A DAYS I STRONGLY DON'T RECOMMEND EVEN TRYING TO REPLACE JUST BEARINGS THEY NEVER LAST LONG AND ITS ALMOST AS COSTLY
HOPE THIS HELPS--CHARLIE -POOL PROS
Sep 04, 2010 | Pentair 3/4hp 115/230v Booster Pump -...
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Mar 31, 2010 | LG WM1814CW Front Load Washer
Loud spin cycle - leaks water
No boot on a top loader, the tub seal and bearing are gone, water leaked from the tub seal, rusted the bearing and quite possibly the milk stool and transmission. Check your warranty, the transmission may have a 5 year limited warranty, usually it will include the tub seal and bearing with the kit.
Jun 13, 2009 | Maytag Atlantis MAV9501E Top Load Washer
Leak from Drive shaft output seal
Does it leak from off the driveshaft?
If yes , thn check the diameter of the driveshaft where the seal lip touches.
May 22, 2009 | 1993 Dodge Caravan
Water leaking between drum and top of gear box.....Washer is an Amanda NAV5800aww
center seal leaking ..repair not for faint of heart if you hire it done be sure they change upper bearing ..water is leaking onto bearing and failure can occur in less than 2 weeks after seal replacement
Oct 03, 2008 | Amana Washing Machines
Washing Machines Logo
93 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
