Question about Frigidaire PLD4555RFC Dishwasher
Brand New overflows PLD4555RFC3
My brand new frigidaire overflowed everywhere and there is still water in the bottom.  I checked the overflow float and it goes up and down.  Not sure if it is just something odd or if I need to try and track down someone to come fix.
  • upschic Sep 15, 2009
    Thanks...it ended up I had a loose screw underneath and the pressure cap (?) on the top was loose, so not only did it leak it couldn't sense the temperature inside during cleaning. I had the tech out twice before it was repaired...overall not liking the performance now that it "works"...it still flashes HO all the time because it can't heat the water fast enough and sometimes it does not finish the cycle so I have to re-run the rinse cycle. This dishwasher is also very shallow, you have to make sure your plates lean or they hit the spinner.
    Problem Solver:
  • 7 Answers
If this is new construction or a new disposal, check the hose that drains from the dishwasher to the disposal - the installer may have forgotten to remove the plug when they connected the hose.
Posted on Sep 12, 2009
Bloomfield coffee maker overflows, even with plain filter
The outlet of the cone filter holder is clogged. Normally its just a hole you can clean out but some units have a valve that is pushed up/open by your coffee pot. That valve may be clogged or if you changed the coffee pot it may not be opening due to the different pot. Clean valve or just remove it so the coffee will run into coffee pot.
Nov 13, 2013 | Lands Phones
Water coming out of overflow
Try getting a coolant tester & making sure that you coolant/water mix is right. Also make sure that you're using the right type of coolant for your vehicle. After that I would check the 2 hoses to make sure neither is plugged. If you have too much water in your mix, it could get hotter and overflow.
Nov 10, 2013 | Kia Sportage Cars & Trucks
1995 saturn! new water pump, and coolant. Changed alternator, and battery, changed oil, oil filter. noticed oily substance in overflow container. did a radiator flush, still has red, rusty color somet
Coolant is oil based. The oily mess in the overflow could be very old coolant. Or it could be engine oil from a leaking head gasket.
The rusty stuff on the floor inside the car could be from a leaking heater core.
Jul 03, 2012 | Cars & Trucks
Car loses water from overflow cap. Replaced water pump, thermostat and overflow bottle and cap.
Stop me if this has NOTHING to do with your problem (or if it's already been solved)...I don't know a lot about cars so...My Ford Taurus kept overflowing antifreeze from the reservoir cap. Car started to over heat and kept spilling"/dumping" antifreeze every time I turned the car off. The antifreeze reservoir had been replaced less than a year prior, and water pump, radiator, etc looked at. I got a free estimate that stated my water pump was NOT the issue, but I did need a new radiator and my reservoir tank needed to be replaced (again)....$800 parts and labor.... However...I noticed the overflow holes on the tank, and also that the orange liquid (antifreeze), was also spilled around the cap lid. I also noticed the CAP on the antifreeze reservoir would loosen when tightened completely- hence, not sealing correctly. So I went to the dealer, bought a new reservoir cap for $15, replaced it, and never had an issue after! I also found out that the CAP was a DEALER PART ONLY, and when the tank itself was replaced, the CAP was the OLD one! Problem fixed! Maybe it's similar? Or something "more serious".
Mar 28, 2012 | Saturn SW Cars & Trucks
Can a brand new top load whirlpool washer model wtw1500vq2 overflow or does ithave automatic shut off?
DEPEND WERE IS THE OVERFLOW IF ITS ON THE DRAIN HOSE ATTACHED ON THE WALL U MAY CHECK THE DRAIN PIPE CAN BE CLOGGED. ANOTHER THING ITS THE WASHER HAVE A WATER LEVER PRESSURE SWITCH PROBABLY BE DAMAGE.
Nov 11, 2010 | Whirlpool Washing Machines
Water leakage inside flush tank
you will need to find out the brand name of your flush/fill valve. some valves merely twist to achieve a new fill level. others work differently. UNLESS, it is the kind with the float ball at the end of a rod. In that case, just bend the rod slightly down if the tank is overflowing.
Apr 20, 2010 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
Ice-maker water overflowing into the freezer/ice-maker.
Possibly the inlet valve.  If it doesn't shut all the way off it will drip water which will freeze in the chute and cause it to overflow.
Dec 19, 2009 | Sewing Machines
Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Mar 30, 2009 | Facebook Social Network
Overflowing and smell
needs a new pressure switch located in control panel are the small rubber hose going from the switch to the tub has a pin hole in it
Nov 29, 2007 | Frigidaire GLWS1233A Top Load Washer
Frigidaire PLD4555RFC Dishwasher Logo
372 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
