Question about KitchenAid KUDR01TJ Dishwasher
I have the same problems.
I had a new heater installed a couple of weeks ago and everything worked fine until this morning. Water in the bottom, and no apparent electric power. This morning our electricity went out for a few seconds and I wonder if that had anything to do with it. I think the heater that was installed might be too much for it. I am scheduling a service repair.
  • 530 Answers
Sounds like you have a blown thermal fuse.
Posted on Jun 24, 2009
Tempra Plus 29 thermal breakers keep tripping, heater will not heat water. Heater was installed last February and worked fine until a few days ago. I've reset the 3 thermal breakers a couple of times... it...
You can find this site but you can't google the manufacturer site.
If you are not able to resolve a problem please contact us toll free at 800-582-8423 before removing the unit from the wall. Stiebel Eltron is happy to provide technical assistance. In most instances, we can resolve the problem over the phone.
Dec 26, 2017 | Stiebel Eltron Tempra 29 Whole House...
Why does my water no come on in the morning when the programmer is asking it too and does in the evening.
Check the time clock is accurate.
If this is a condenser boiler [it has two water pipes to the outside] check that the pipe from the condenser is not blocked with ice, if so heat with a heat drier
Oct 17, 2014 | Water Heaters
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 14, 2014 | Water Heaters
Heater works fine when its turned on but stops blowing heat after 3 mins.
mine just did the exact thing. I took it apart and blew it out with an air chuck and it works like new again. a couple of weeks ago i used a vaccum and it work a couple of days and then did it again. The squirrel cage and heat elements were filled with dust. It was not easy taking apart but now i know to only take the bottom off. thanks
Nov 18, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Installed Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD a couple months ago. About a couple weeks ago experienced low flow for about 4 hours then started working fine. Now...
Remove spay head from the end of the sprayer hose and turn the water on. If you have good pressure without the head, call Delta and ask for a new spray head. If you still have low water pressure without the spray head attached, call Delta and ask for a new ceramic disc cartridge free.
Sep 01, 2010 | Delta 16955-SSSD Stainless Steel Victorian...
Film on dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 12, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
KitchenAid KUDR01TJ Dishwasher Logo
140 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
