Icing up air conditioner carrier 38tg - Heating & Cooling
  • 24 Answers
Check your filter. If its really plugged that would cause to ice up or if its low on refigerant that would also cause to ice up.
Posted on Jun 24, 2009
Carrier Air conditioners
change filter and clean outside unit with water. pull the outside fuze before cleaning.
Jul 29, 2012 | Heating & Cooling
I have carrier heat and air model numbers 58sx and 38tg what sizes are these
You need more information to get the size. The Carrier 58sx series includes 5 different models: 40 - 41000 BTUH, 60 - 61000 BTUH, 80 - 81000BTUH, 100 - 102000 BTUH, 120 - 122000BTUH. An installation guide for the 58sx is available here: http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/58sx-14si.pdf . The Carrier 38tg has 6 different sizes (020 - 20,000BTUH through 050 - 50,000BTUH). The other sizes are 025, 030, 035, 040 and the capacity is that number multiplied by 1000.)
To determine your model's capacity, look at the full product number. The first three numbers after the 58sx or 38tg will indicate the nominal capacity.
I hope this helps.
Oct 25, 2011 | Heating & Cooling
My air conditioner line is freezing and no air is coming out of the vents
Shut it down for a few hours and let it De-ice the evap coil is iced up/ check your filters and change them.. Oh to speed things up a bit. Just shut the cooling off and leave the fan on that will speed it up. You should see ice or condensate on the line. But set your stat to 74 and close doors to rooms not in use..
Jul 14, 2011 | Carrier 38CKC042 Air Conditioner
I have a carrier air conditioner model 38CKC024340 it cool the house sometimes, then a block of ice will form on the unit outside and it stops cooling, what could be the problem
Have you changed the air filter?
The 2 main reasons for frozen units in cooling mode 1. Not enough air flow. 2. Low on refrigerant.
You can fix #1.
#2 will require a service call.
Jun 02, 2011 | Carrier 38CKC024 Air Conditioner
The motor area is iced up on the machine, and the fan is not blowing cold air?
you will need to clean the coils, with a water hose. make sure you have the power off. This will de-ice the unit. as it is either diry coils or low freon
Sep 12, 2010 | Carrier 38CKC036 Air Conditioner
Carrier N3 flashes three times (catalogue says "indoor coil sensor malfunction"). How can i fix this??
Hello THECOOL The sensor is a freezestat sensing ice.Try a new air filter.Low air flow is a cause of freezing make sure the intake is not blocked and all the supply outlets are open.
Aug 03, 2010 | Carrier 38CKC042 Air Conditioner
Plentiun air conditioning coils are icing up after running in cooling mode
frost or ice on an a\c coil has 2 causes poor air flow or a low referigant charge. poor air flow could be a ditry air filter, blower wheel or a coil. a low charge is a leak in the system
Jun 17, 2010 | Carrier 38CKC036 Air Conditioner
Air conditioner runs but no air comeing threw vents
Hi make sure the indoor blower is running first of all. Check to see where the blower motor is that it is not iced up. This happens when you don't have enough return air back to the unit. I have see these coils have a solid block of ice 4" thick on them. Check this and the motor and you will find the problem. You will have to de-ice it. Check the coil to see if it is dirty also. Clean if needed.
Shastalaker7
Jun 13, 2010 | Carrier 52CE215 Cool Electric Heat Air...
Carrier heat pump has ice on outside pipe leading to unit. Air not cold inside. Any suggestions???
this is sign of low freon. you have a leak and ice is clogging the interior coils so little or no aire can pass thru it. Cut it off and find the leak.
May 04, 2009 | Carrier Heating & Cooling
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
