I have an Element Electronics outdoor wireless set of speakers and the antenna transmitter.(EW0S1) Do you have a compatible wireless stereo headphones set available? If so, how can I obtain it & costs. I am in the South Florida Pompano Beach area. Thank you. Gilsilb5@comcast.net
SOURCE: logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Posted on Mar 19, 2008
SOURCE: EXTERNAL SPEAKERS ARE AS LOUD AS THE HEADPHONES WHY?
The ability to turn off the external speakers of the radio being plugged into has to do with the capabilities of the radio itself, not the headphones. Most radios will automatically disable any built-in speakers when you plug headphones in but yours may require an extra step. Check your radio manual to see if it has a switch that can do this.
Posted on Apr 12, 2008
ginko
  • 19396 Answers
SOURCE: Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Posted on Jul 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: I have a set of
They went bankrupt because their so called air cleaner weren't cleaning anything in fact there were studies conducted that it was doing the end user more harm then good.
Has Sharper Image took the time to read the EPA research on ionizers in the first place, they could have save themselves a great deal of trouble.
It looks like your out of luck getting it fixed but finding a replacement shouldn't be a problem.
I believe Bose makes a similar product.
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
My husband three away my transmitter to my Centrios 900 MHZ DIGITAL HYBRID WIRELESS OUTDOOR SPEAKERS. #4015004
So many of these things are made generic and have limited production run. The OEM is not traceable. I
would recommend getting the whole set.
Jun 05, 2017 | Centrios Audio Players & Recorders
I need a transmitter for a set of rca wsp150 WIRELESS SPEAKERS. CAN I SUBSTITUTE? Where can I buy one?
head phone set WHP141 will work with that set of speakers, look on Ebay
I have a set of the same speakers.... make sure that your transmitter is actually bad, it does not power up with the GREENLIGHT staying ON UNTIL the sound source is hooked up and has enough INCOMING volume to trigger the transmitter on.........
Oct 27, 2011 | RCA WSP150 Main / Stereo Speaker
I have the advent wireless speakers, aw820 and they work if the CD is playing and the receiver is set to CD. However, when i use my ipod (with the receiver set on TAPE) then the WIRELESS speakers will not...
I do know that the transmitter would not transmitt the HD audio. I had to also hook up the analog signal from my DVR and BLU RAY so the sound would get transmitted from the amp to the transmitter and on to my speakers
Nov 22, 2010 | Recoton Advent Advent AW-820 Main / Stereo...
This tv is not connected to cable or dish, but has an interior antenna. up to about 2 months ago, we could get network channels (abc, nbc,cbs) which is all we wanted. Suddenly CBS dropped out, says "no...
How far away is the CBS station? Are there any obstacles that would block the signal (say new construction)?
What channels do antennaweb.org or tvfool.com suggest you will get from your location? (Antennaweb is more conservative and assumes an outdoor antenna.) Do you need to rotate your antenna to get one transmitter or the other? Indoor antennas are more likely to get interference and direction issues.
You may want to restore your TV to the default and then rescan the channels. (This may or may not help. It usually helps more with scrambled information than lost channels.)
I hope this helps.
(good luck. I've had issues with my CBS and Fox affiliates (sharing a transmitter location). At first it was clearly my TV and the reset helped. Now I have no clue as to the cause - the external TV antenna gives a strong signal on the other TV. The problem TV says the signal is bad and this is the closest transmitter and antennaweb says I should get it easily. Even pointing the antenna straight at the transmitter doesn't help.)
Jun 10, 2010 | Element Electronics FLX1511B 15 in. LCD TV
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
Sep 18, 2009 | Bose Indoor/Outdoor Speakers (Pair) -...
Instructions on how to hook up outdoor speakers to computer
Get a set of wireless speakers (such as Advent AW-820 900 MHz Wireless Stereo Speaker System).  Connect the transmitter to the earphone jack of your computer.
May 20, 2009 | KLH Audio Players & Recorders
Element Electronics Wireless speakers (model#EWOS1) do not work.
I have the same exact problem!!! HELP!!! If you found out how to fix this, please please please let me know!!
divawoman1@yahoo.com
Feb 23, 2009 | Electronics - Others
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Jul 19, 2008 | Audio Players & Recorders
$150 wireless speaker
use a expanded module for input/output RCA ports, Radio Shack
Jun 15, 2008 | Brookstone Outdoor Wireless Speaker...
108 people viewed this question
 Grubhead
Grubhead
