Question about Goldstar DH504EL Dehumidifier
Goldstar GHD30 is dead
Unit is approximately 2 years old and was unplugged and stored for the winter. Tried to power it up and no luck! Troubleshooting leads me to possible sensor issues. I say this because I can have voltage on teh circuit card and can get the fan or compressor to run by shorting out the switches. Anyone know the approximate sensor resistances? Any other ideas? BTW, bucket switch is working properly as well.
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: GHD30 dehumidifier completely dead
If any machine is completely electrically dead it is a sign that there is no electrical voltage getting through to operate it. Using an electric meter it is a relatively easy task to find the point of differential voltages which would indicate where the open circuit is located. The blue green fluid found is from copper oxide and is not necessarily indicative of a refrigerant leak. Oil present would be an indicator of a refrigerant leak.
Posted on Nov 17, 2008
SOURCE: won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Posted on Jun 23, 2010
  • 83 Answers
SOURCE: Product Goldstar Dehumidifier GHD30: Machine
Hi
You need to check that the bucket is clean and that the sensor for the water level in the bucket is clean.
An old toothbrush and some warm soapy water can sometimes achieve a great result.
Failing this you may need a new sensor, be careful and either draw or photo the old wiring route with your cell phone to make it easier to fit the new sensor
Hope this helps
Gordon
Posted on Apr 17, 2011
MOTORWIZJ
  • 1383 Answers
SOURCE: Have a Goldstar Dehumidifier GHD30.
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Posted on Jul 25, 2011
Model GHD30 will not run. Have power to the board. I can hear a click noise when turning the switch on. I electricially checked the compressor and fan both ok. PCB board?
Jim, you may also want to check the water bucket installation, too. If it is not properly installed, the unit will not turn ON. Also, check the float valve in the top of the bucket. It may be stuck in the UP position. In which case the unit will not start. Giggle the arm of the float valve to get it to return to the DOWN position.
Hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 27, 2011 | Goldstar DH504EL Dehumidifier
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
Model GHD30 dehumidifier-runs for a few minutes then shuts off. Will start again after a few minutes then shut off again, and so on. Does not seem to be "dehumifying" when operating.
As I have told many questioners, There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If your unit does not have an
LED screen, turn the control to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem.
Jun 24, 2011 | Goldstar Dehumidifiers
Product Goldstar Dehumidifier GHD30: Machine runs when red button is depressed by hand. Return water bucket and machine stops. Set theromstat controller on max, and when button is depressed it works and...
Hi
Hope this helps
Gordon
Apr 17, 2011 | Goldstar DH304 Dehumidifier
Won't come on
Jun 09, 2010 | Goldstar DH304 Dehumidifier
Goldstar ghd30
Make sure condenser is clean.
Apr 10, 2010 | Goldstar DH304 Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Nov 01, 2008 | Goldstar DH504EL Dehumidifier
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
367 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
