Question about Kenmore 22422 Top Load Washer
Kenmore elite washer machine
I have a kenmore washer machine which is not starting when I push the button the left side panel for wahing on permanent/normal/heavy duty wash cycle it does not turn on when I use another cycle of the panel on ultra/express wash the machine works.
Can you advise me on what would be the problem since some of the cycles work and the main ones don't.
Thank you
  • Anonymous Dec 09, 2007
    checked the plug,breaker,and still nothing! small load too,frustrated! no response from turning dial
  • yuyo Dec 21, 2007
    I checked and change the condenser (round big piece) which is on the right side behind the control panel. I found that was the problem because when I tapped the condenser it would start and then when I would try later on to use the washer machine it didn't start again and I had to tap that piece. Finally I changed the condenser and now is working like new.
  • 288 Answers
The selections are all made by the timer control. I would look to this. Before replacing it, make sure the harness is connected nice and tight in the back.
Posted on Dec 19, 2007
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My Kenmore Elite washer model 110.27062600 stopped working. All the front panel lights are flashing on and off for 7 times then pauses and starts blinking again. The machine will not do anything. No...
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Sep 19, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
I have an HE2 Elite Kenmore front load washer. I
Sounds like a control board issue. Not much else for you to do but wait
Nov 19, 2009 | Kenmore Washing Machines
Removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
HE3 Washer just keeps beeping at me when I push the start button
Bad motor pump and it's a common problem kenmore elite front load washer so we need to left the washer from the front and get under the washer to get the motor pump replaced
Nov 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
