Question about Motorola Mobility V120c
Does not ring
My phone does not ring. Calls just get sent to message manager
My wife's phone has suddenly quit ringing. Incoming calls are sent immediately to voice mail. Her Messenger app also won't work. Settings are correct and nothing was changed.
Please double check the settings in the message direct of the phone's unit if this is a android unit there is a settings there's an option for voicemail forwarding / message forwarding just turn off that option. If this is a Apple unit please do contact the Apple's technical team department.
Aug 07, 2017 | Cell Phones
Pls tell me how can I see the time i talked in my phone? how can i see the time of all talking? and where can i see how mch sms did i send and accept? pls tell me! THANK YOU!! I got nokia n8
To see your call durations on a Nokia phone.
  • Press Menu
  • Press Log, which is a green and blue arrow
That will get you into recent calls,,,,,,,,Missed, Received and Dialled calls.
Scroll down to Call Duration which will give you total time for , Last call, Dialled numbers, Received calls, and All calls.
SMS, go to Messaging
  • Inbox tells you how many sms received
  • scroll down to Sent messages to show how many sms sent.
But that depends on your settings on your phone, go to,
  • Messaging
  • Options
  • Scroll to Settings
  • Scroll to Other
  • From there you can change Number of saved sent messages you can store.
I hope this was helpful
MobileJB
Jul 13, 2011 | Nokia N8 Cell Phone
How can i disable busy tone sent on W595
The busy tone from your cellphone is sent when you are busy with one call & there is another incoming call. The following solution is only not to avoid certain callers or to avoid all callers. It may or may not serve your purpose. For this facility to work you have to make group/s of the certain callers & select them in manage calls.
If you want to disable busy tone sent, you can do it by selecting menu - settings - calls - manage calls - accept calls - only from list or none. In this case the person at the other end will receive "not reachable" message.Selecting only from list allows you to receive the calls from the selected groups/callers from your list. Selecting none will not allow anyone to call you. But in both the cases only you will know that who has called you & not the caller that you received missed calls.
sonsunny
Jul 06, 2011 | Sony Ericsson W380i Cellular Phone
Need to hear the phone ring. It goes directly To message manager and I miss all phone calls in real time Please tell me how to turn it off for ever. I
Hello
First the reason your phone goes to message manager is because the the phone is set on voice mail or message manager. If the phones name was stated, then i would have been able to guide you through the process of getting it off.
But a general code to enter to get your phone ringing is for you to dial ##002# then send it, after doing that, then you can try the number using another phone, to test if it has stopped going to message manager.
Take care.
Hope this helps
Dec 18, 2010 | Cell Phones
I have sent two messages to you concerning my phone. My phone rings and I cannot Talk to whomever calls! I have given you my credit card numbers, phone Id, and All I have seen Is a little circle in the...
While the phone rings, does the answer button responds? Or do you pick the calls and you cannot hear the person from the other end?
I would like to be sure about the above question so the I can give you an accurate solution.
I would be expecting your reply.
Take care.
Dec 30, 2009 | Cell Phones
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Oct 01, 2008 | Panasonic KX-T7633 Corded Phone
Motorola Mobility V120c Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
