Question about Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Trying to use the Polti Vaporetto 2400, the tank is full (2 liters) and the steam gun attached. It starts to heat up, but as soon as there is just a little bit of pressure, the water out light comes on and the pressure does not get any higher. There is very little spray comes out when the trigger is pressed, which stops after 1 second.
Found there was a fair bit of scale in the tank. Rinsed it out well, but this didn't fix the problem. Even tried filling with boiling water from the kettle and adding kettle descaler. Left it a while and rinsed out well. It hasn't helped.
Any suggestions? Thanks, Andrew
    Problem Solver:
  • 17 Answers
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Posted on Mar 11, 2008
    New Friend:
It's a brand new iron
Posted on Nov 22, 2013
Heats up ok but no steam when temperature reached
Water indicator light keeps flashing and bleeping even when iron is full ,this is a brand new iron.
Sep 26, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
It is getting up to tempeture but it will not produce any steam
Your machine need to reach boiling point to produce stem? Then check if all the sustem is sealed other than the pip outlet gun and it should now operate with the gun trigger ( pull to operate, but only when the water within the vessel is boiling, producing steam)Hope this helps Regards Mike
Jul 08, 2011 | Polti Vaporetto 2400 Canister Steam Vacuum
Lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
May 31, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Vaporetto 2400 no access to water tank
The threads have probably stuck together with limescale. Push down with reasonable force while turning the cap, like you would if you were trying to get in one of the childproof bottles. This should crack the limecale and allow you to take it off. Then descale the threads on the top and machine using kalstop or whatever you use.
Jan 16, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
1,120 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
