Question about Poulan "Poulan" Push Mower
Carburetor adjustment Poulan Pro push mower spark plug being flooded with gas.  How to stop it so I can get to mowing all this grass...Thanks Patty
  • 84 Answers
It would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
Posted on Jun 24, 2009
I have a poulon pro 42cc saw that wont start. dont think its getting gas cuz i tried to flood it with the primer but no gas on the spark plug.
The primer will not flood it, all the primer does on these saws is pushes fuel through the carb. If this is a new saw, it needs a carb adjustment, a very common problem on poulan products these days. It's covered by the warranty at any of their service dealers (you can locate one on poulan's website).
How old is the gas you are using? If the mixture is more than 30 days old, make a new mix and try again.
Check for spark. Pull the boot off of the plug. Hold the boot near something metal and pull the starter. If you see a spark, you are good. If you don't, you may have a problem with the coil.
Aug 26, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
My bolen push mower won't start, it worked two weeks ago. Gas and oil are full. where do I go from here, change spark plug?
see if it has spark. try to trickle a little gas into where the carburetor is and see if it will atleast fire.
May 01, 2010 | Poulan "Poulan" Push Mower
Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Oct 04, 2009 | Poulan Pro " Pro" Self Propelled Mower
Spark plugs are being replaces every 3 or 4 mowing
the carb is located under the aircleaner it sounds like the mower is being fan at full throttle this on some mowers applies the choke try ajusting the throttle to full then slightly back to open choke.
Jul 14, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Poulan "Poulan" Push Mower Logo
757 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
