Question about Compaq Computers & Internet
My laptop will no longer connecr to the internet
I have a Compaq presario f700, one minute the internet was working just fine, I close it maybe for an hour to do something else, and when I come back it is no longer connecting to the internet.I've tried re installing the wireless driver and updating vista, but nothing seems to work.
    Sniper:
  • 51 Answers
Make sure that your modem is working, test another modem to know if it is working or there is internet connection... because sometimes the problem is not on software it is on hardware..
use this link for internet troubleshooting
http://www.onecomputerguy.com/networking/troubleshoot_internet.htm
Posted on Jun 24, 2009
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
I have a Compaq Presario F500 When I press the power button all the lights light up for a few seconds then it shuts back off
remove the battery then try to plug the charger directly on your laptop without a battery.. to test if the battery is working properly. if not.. maybe your main board have a problem. just like athe compaq presario of my friend. also mainboard problem.
Jul 10, 2011 | HP Compaq Presario F500 F700 and G6000...
I have a Compaq Presario F700, how can I activate s-video out?
On most laptops it a simple case of pressing two buttons together, usually th 'FN' or 'Function' Key and 'F5' (press fn first, hold down then press f5) Yours maybe slightly different and use a different F key ie F3.
Nov 22, 2009 | Compaq Computers & Internet
My laptop will not start
OK. When the AC adapter is plugged in the computer should boot and stay on. Most likely the adapter has malfunctioned or the female connector has come loose from the mother board ( a common problem with all laptops). Check your adapter by measuring the output voltage with a voltmeter, taking it to a repair shop, or using it on another computer. If it is bad, get another, if not, disassemble the laptop and resolder the power connector to the board. Test it before complete reassembly and glue the connector to the board with a few tiny spots of five-minute epoxy. The 5 minute stuff is easy to remove with heat if need be. You can find assembly instructions for your laptop on C-net. Repost this if you need more instructions and I will guide you through it.
Good luck to you.
Aug 22, 2009 | HP Compaq Presario F500 F700 and G6000...
Can i switch an lcd screen from a compaq f700 to a cpcq60?
You don't know if you can swap the LCD screens until you dismantle both screens and compare them side by side. The video and inverter connectors maybe different.
There are companies on the Internet that sell replacement LCD screens.
One of the ones I use is LCD Parts, use this link to their WEB site.
www.lcdparts.net
Aug 06, 2009 | Compaq Presario 700 470024-192 Notebook
Installed McAfee on Compaq Presario F700. IE7 frozed up.
If you have McAfee Internet Security, there could be some settings that have disabled connection. I had this issue with McAfee once myself.
Open the McAfee security center and try to tone down any firewall settings, antiphishing, etc. For me, I turned off antiphishing and firewall altogether and it worked, but maybe not recommended.
Apr 20, 2009 | Sybase PowerDesigner DataArchitect 9.0...
if u want Drivers for Compaq presario F700 please use below link for win vista Os ..there is all drivers for u r laptop
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=3629568&lang=en
If this link is useful for u please rate me...........
Jun 14, 2008 | Compaq Presario 700 470024-192 Notebook
Presario f700 drivers
You have to download XP drivers from the manufacturer's website. This normally happens because your harware was designed for the new OS(Vista).
Just go to hp.com and search for the model of your Laptop.
May 20, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
115 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
