Question about LG DLG5988 Gas Dryer
After 3 years of reliable service, my LG DLG5988W Gas Dryer starts giving me problems. When I try to dry a load it and press start it feels like it wants to run, but just hums instead. I can open the door, press the button to fool it into thinking the door is closed an manually spin the drum and it will then work just fine...just have to be quick and close the door. What can the problem be?
  • 146 Answers
That is the safety switch probably need to be replaced. or make sure the door is closing all the way.
Posted on Jun 24, 2009
Where can i get parts for an LG gas dryer number DLG5988W
http://www.repairclinic.com/Shop-For-Parts/a8b200d684294/Model-DLG5988W-LG-Dryer-Parts
Sep 08, 2014 | LG DLG5988 Gas Dryer
Does my lg tromm dlg5988w gas dryer have a pilot light that stay on all the time or only when u start it
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | LG DLG5988 Gas Dryer
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
LG Gas Dryer (Model # DLG5988W) is not heating, the gas is not turning on. When the dryer is turned on the ''Check Filter'' light comes on and when switching to a drying cycle the ?Cool? light is always...
The dryer has a resettable SAFETY thermostat located on the flame tube inside the dryer. LG recommends replacing the Safety and High limit thermostats if the Safety thermostat is tripped. The dryer Glow bar igniter could be bad as well as the gas valve or Main computer. Time to have the dryer serviced by a qualified LG tech. LG has factory service tech in most large cities. Give them a call at 1 800 243-0000.
Hope this helps.
Mike
Oct 31, 2017 | LG Dryers
My LG gas dryer DLG5988W
somethin might stuck down insinde the channel where the llint filter goes, small sock baby tee or somethin to that effect, it rests against fan and prevents motor from turning, usually lookin down with a flashlight will confirm this
Mar 02, 2008 | Dryers
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Dec 20, 2007 | Dryers
LG DLG5988W DRyER NOT DRYING
Sounds like you have solved your problem.
Sep 26, 2007 | LG DLG5988 Gas Dryer
LG DLG5988 Gas Dryer Logo
385 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
