Question about Toshiba Satellite M115-S1061 Notebook
"Sound device not found" satellite m115-s1061
No mixer devices found
No volume control
Sound card doesnt show up in BIOS
Device Manager: no audio device
I've tried the Troubleshoot fixes
Is my sound card fried. is an onboard card replaceable?
If not, will an external sound card work with my internal speakers?
Thanks so much!
  • 341 Answers
Make sure when the computer first starts up that you enter the setup BIOS( by either hitting f2, Delete, or whatever for you specific computer and there should be setting on one of the pages to either enable or dissable onboard sound. Sound cards don't interact good with anything else that is in your computer or anything that you may have recently installed such as an add in usb card, ethernet card, whatever. But you basically need to find out where your sound is coming from. An adapter card or onboard. I highly doubt you fried anything. But if so there are ways around that so don't despair. Get back with me if you need to a give me some more indepth info on your computer. Thanks
Posted on Jun 24, 2009
No sound
Install an appropriate driver. Go to device manager, to make sure that your sound card is detected by your OS. Also you could check in BIOS that audio is enabled.
If there is no problem with one of those, it might be hardware problem..
Aug 05, 2011 | Toshiba Satellite M115-S1061 Notebook
My toshiba sat M115-s1061 forgot bios password. When I power on the laptop, it appears the scren with a blue box asking for: enter password.
http://answers.yahoo.com/question/index?qid=20100215063247AATJ4oQ
I found this. It doesn't sound good.
http://forum.notebookreview.com/toshiba/190972-toshiba-m115-s3094-bios-password-reset.html
This^^^
May 29, 2011 | Toshiba Satellite M115-S1061 Notebook
No sound on HP 1140n desktop computer NO audio
enable the o board sound card from bios
Mar 23, 2011 | HP Computers & Internet
Can't play any sound files
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reginout to scan for errors.
Nov 25, 2010 | Toshiba Satellite M115-S1061 Notebook
My Saffire Le doesn't show up in AUDIO DEVICES but all is instaled corect and in my device manager I can that fire wire and Saffire are ok please try to help... it began after I reinstaled windows (now...
Go to Volume Controls - Options menu - Properties... is it in the Mixer drop down box there? You might find the problem is that any onboard soundcards you have on the motherboard are now set to default since you reinstalled. In which case go to device manager and disable it. If problem persists try a reinstall of saffire whilst the onboard card is disabled. Some motherboards allow you to disable the onboard sound from the bios menu too, that could be something to try
Oct 31, 2009 | Focusrite Saffire LE Sound Card
No sound
if there is a knob on the laptop turn it until its all the way up...
then go to the volume control turn it up
reinstall drivers if you need to
go to a certified tech if you can.
Sep 30, 2009 | Toshiba Satellite M115-S1061 Notebook
Volume and the dvd lector are not work
I assume the problem you have is not being able to read CD's or Burn CD's with this device. Try updating your Drivers from the Manufacture of the device. I see this problem often but most of the time it is on older model Compaq systems. If the driver install doesn't work then you most likely have a bad drive. Download the drivers, go to device manager and remove the device, run the install program for the drivers and reboot the system. If you try to install the new drivers when the device is in device manager windows has a tendency to not do a complete correct install.
Aug 26, 2009 | Toshiba Satellite M115-S1061 Notebook
Hi i'm just new at this. we have no sound what so ever. i found the sound chip number or something. how can i get my sound back online again?
1. Lets start with the obvious. Make sure the volume mixer control is not muted. This is usually a speaker icon at the bottom of the screen. If you do not see this then go to control panel, sounds and audio devices, and make sure nothing is muted.
2. check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
Jul 09, 2009 | Apple Griffin iMic External Sound System
No sound device found
check for devices in "other devices" in Device manager
Oct 22, 2007 | Computers & Internet
Toshiba Satellite M115-S1061 Notebook Logo
286 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
