Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Do you have a picture of how a 3.5 hp verticle shaft carbuerator linkage should be
    President:
  • 3,433 Answers
You can go to this site and look around - Good Luck, Ned
Posted on Oct 31, 2009
Troy-Bilt w/Tecumseh HMSK 80-110 engine. Where can I get a repair manual covering the carburetor OR a picture showing carb linkages?
There are a couple of reasons this could be happening.
1- The throttle shaft could be frozen or gummed up where the throttle shaft sits in the carburetor body.
2 - Check the top of the throttle shaft where the shaft meets the plate, if it is loose or separated it will not allow the throttle plate to move.
3 - The governor spool may be damaged internally in the engine.
Added a couple of Tecumseh manuals below.
http://www.barrettsmallengine.com/manual/tecumsehcarburetormanual.pdf
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Jan 29, 2016 | Garden
Craftsman lawnmower wont stay running
Michael it sounds like there may be a blokage on you air filter. Check it and clean it then make sure there is not too much oil in the mower.
Jul 18, 2013 | Garden
32" Sanyo picture is half verticle lines various colors, half ok picture
Bad Tcon board or the cable going from the board to the panel, try that first by cleaning both ends if that doesn't help you need a new board
Jan 27, 2018 | Sanyo DP32746 32 in. LCD Television
Carburator linkage
The governor link hooks on the top right of this carb and the throttle linkage is on the left all this is you standing in front of engine looking toward the steering wheel with the hood off
Sep 03, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Hi, i have an 806 international tractor. it will shift into hi ,lo, and reverse but i have to go from neutral to hi several times before it will go into hi gear and this also happens in reverse. i have no...
linkage is worn. remove deck plate and check shaft going through range cover to see if ts worn.also check arm on verticle shaft to see if keyway is worn. these parts are availeable from your local caseih dealer
Mar 19, 2011 | Farmall IH Tractor 706, 756, 806, 856,...
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
CARBURETOR AND GOVERNOR LINKAGE LOCATION
Go to this LINK and find the part/diagram that can help you.
Nov 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need help with cub cadet lt 1045 engine running erratic after a minute on full throttle Engine starts fine and idles fine. once you put it in full throttle after about a minute or five minutes it starts...
Anthony, this could be from the governer linkage which is intended for maintaining a specified top rotation per minute speed ( R.P.M ) is a possability im not sure of your specific adjustment procedure allthough most are a simple lossening of the linkage mounting to the shaft bolt while this bolt is loose you push the linkage to full throttle travel activation allowing the control linkage that was lossened to turn in its mount ( pivot) and keeping the threw the block mounting at full activation range ( travel ) in its farthest position re tighten the arms securing bolt,to secure it at its proper activation range ( at the pivoting point) I hope this helps if your unfamiliar with this type of governer control linkage, i would seek to locate a diagram on line that you can view to assist in your specific engine's linkage adjustment , and another possability is your carbuerator's High speed needle valve is to lean or to rich hope you analysis the problem Steve
Aug 01, 2010 | Cub Cadet Garden
1997 Dodge Ram Van gas pedal stuck almost had wreck?
I honestly don't see how changing the computer could cause this - I would first suspect a broken return spring on the throttle body. With the engine off, trace the gas pedal's linkage (or cable) back to the point where it attaches to the engine (throttle body or carbuerator if not fuel-injected). There will be a shaft it attaches to on the throttle body (or carb). Disconnect the linkage at this point and try to rotate this by hand, it should snap back when released. If it does, you probably have a 'frozen' cable which needs replaced. Don't forget to replace the linkage where you removed it now. If it doesn't, look for a 'missing spring' on the throttle body's side or any place the linkage appears bent or could 'snag' on anything. If the attachment point doesn't rotate smoothly or 'binds', or kind of 'wobbles' in it's holes the shaft bushings need replaced or the shaft is bent and needs rebuilt. While your'e there, regardless, you should take some 3-in-1 oil and lightly lubricate any points where the shaft, cable, or linkages touch any other part.
Nov 15, 2008 | 1997 Dodge Ram
HP PE4240N Lines in picture
go to this link and read carefully!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Dec 20, 2007 | HP PE4240N 42 in. HD-Ready Plasma...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
170 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
JOHN LAPIER
Matt Olenzek
Matt Olenzek
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
