Can barely hear the words through the heavy static on AM only. FM works fine. Other vehicles have no static and clear reception so its not "something in the air". I have heard coils can cause this. Any other ideas to try?
How about checking your antenna? You might have poor contact or none.
As suggested it could be underhood electrical interference. If the "static" changes with increased rpms (rev the motor to find out) chances are it is ignition related and could be literally everything from the alternator to the ignition coil through the distributor cap, but best bet is the spark plug wires (which if still original really should be replaced anyway) or the plugs themselves. If your am static doesn't change with engine revolutions and your fm works okay I would check antenna and the antenna connections at the base of antenna and back of radio. if you cant even get a clear signal on the most powerful AM station in your area, I would bet on some kind of break in the connection between radio and antenna. p.s. if you;ve anything plugged into cigarette lighter or other 12volt outlets in the vehicle unplug them before doing any of the rest!
SOURCE: 2004 lincoln navigator air suspension my truck is lowered from th
could be faulty compressor which pumps up the suspension,is it leaking from anywhere,causing the pump to work too hard,has it just packed up,check fuses but probably compressor
SOURCE: front air suspension stopped working
Vehicle Dynamic Suspension
The four wheel air suspension system is comprised of the following components:
Visual Inspection Chart
Mechanical
Electrical
SOURCE: 2004 lincoln navigator, air suspension
check how old are the suspensions on ur navigator. if they are pretty old, they need replace.
