Question about Zebra 105SL Thermal Label Printer
Cutter jammed - Zebra 105SL Thermal Label Printer
    Problem Solver:
  • 9 Answers
If you take the side off, and then the power supply, you will see a sensor and a flag, check for wear / damage. sometimes the allen bolt that holds the lower cutter linkage can come loose. try cleaning the sensor. also the connections from the cutter board need cleaning with ipa. if that doesnt solve the issue, you can take the cutter off, remove the silver plate and remove any label debris. if all this fails to solve the problem you will probably require a cutter board or sensor.
Posted on Jul 14, 2009
  • nama saya
    nama saya Jun 03, 2014
    change new cutter board still up cutter jammed
Zebra 110xi4 labels jam going into the cutter
This is usually related to the setup of the printer. Check that there is no backfeed set up, and that the settings are on for calibration on head close.
Oct 10, 2012 | Zebra 110Xi4 203DPI 10100 CUTTER W TRAY...
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
The paper cutter on the Designjet 130nr jams all the time. Help? Where are the screws for the cutter?
from memory this cutter is removed by removing the side cover and sliding it off the end of the carriage rail.
Aug 15, 2011 | HP DesignJet 130NR InkJet Printer
Paper jam sign appear all the time
If you get this error check for paper jam and see if the paper cutter is seated right and is not defective. You can try cleaning the cutter and lubricating it, even then issue not resolved replace the gear train.
Dec 10, 2010 | Brother Office Equipment & Supplies
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
PX1200MX middle cutters jammed, bent, won't cut
For replacement parts give Royal a call at 1-800-524-0799.
Oct 11, 2009 | Royal Office Equipment & Supplies
Fellowes PS60 CC shredder jamming
You have guides or cutter assembly out of alignment. Take it apart and double check before reassembling.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 09, 2009 | Office Equipment & Supplies
My zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Mar 26, 2009 | Zebra Z4M Printer
Panasonic fax
If there is a cutter it might be defective,try to off the cutter.If the is no cutter check paper sensor.clean or replace it
Mar 06, 2009 | HP FAX 1250 Fax Machine (Black)
Zebra 105SL Thermal Label Printer Logo
1,232 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
