OUR WINDOW UNIT AIRCONDITIONING MAKES A FUNNY NOICE
OUR WINDOW UNIT AIRCONDITIONING MAKES A FUNNY SLURPING SOUND IT IS BRANDNEW!!!!HOW CAN WE FIX THIS? it is a haier window air conditioner HWF05XC7-2
  • 434 Answers
Is the unit leaning slightly down in the back. If it is sitting level, the water can't drain out of it.
Posted on Jun 24, 2009
GE electric Dryer model GDX8060SW will not start, makes a humming noice only. Exhaust duct was clogged with lint, which I removed. Still only humming noice when trying to start Dryer. Is there a reset...
could have a jam still in the blower wheel and all...sounds like unit is getting power and trying to start if your getting a hmm but something is keeping it from turning...gain access to the blower area and check a little deeper for more obstruction...aso make sure belt did not come off of motor maybe motor is humming but not turning unit....
Jan 03, 2011 | Dryers
AKRAIR AIRCONDITIONING OPERATOR MANUAL
I hope this is not a trick question. What is it doing in the motherboard section?
It might help if you provide the name of the manufacturer of the airconditioning unit. Is it a portable or a fixed unit?
Oct 08, 2010 | Computers & Internet
My haier 5200 btu window ac is making funny nosies from the fan like its hitting something I have tryed to wash the outside of it but its still making noises
If you remove the unit from it's housing by sliding out, you can run it while it is out. This will enable you to see exactly where the sound is coming from. Very often it is because the unit is slightly out of alignment with the outer housing. This can be fixed with a spacer.
Oct 20, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Way too loud
it is prob. a pipe vibration, window unit are not knowen for quiet running
May 02, 2009 | Goldstar KG6000R Window Air Conditioner
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Car squeaks at idle when warmed up
it could very well be just your serpentine belt is old, they usually squeak when worn. To solve that you can buy a spray at any local autoparts store to stop the noise for good, its called belt dressing. a slurping noise could be a range of things, the most common is your
a/c isn't fully charged with fluid, the noise your hear is the compressor trying to pull more fluid in **** only getting air, hence the slurping
Mar 21, 2009 | 1994 Honda Accord
My garden tractor makes a funny noise when i put it in drive
Wrong belt size? Did you put everything back the way you took it off to put the belt on? Usually, it's the belt, if it doesnt fit tight it will vibrate, have a burning smell and wont let you shift smoothly.
Dec 29, 2008 | Garden
Kenmore aircondition
First is to make sure the evap and condenser coils are very clean. A dirty evap coil will cause icing as well as a blower not running and low freon. Hope this helps. Thx RepairUSA
Aug 31, 2007 | Kenmore 75050 Wall/Window Air Conditioner
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
