Question about Kenmore Refrigerators
My refrigerator making really loud noise. What's wrong with it?
  • Mark Nichols May 11, 2010
    where is the noise coming from? inside or outside? and what kind of noise is it?
  • Kenmore Master
  • 4,655 Answers
I will help you find the problem and solve it. You need to tell me where the noise is comming from and look on the model plate listed in photo below and get the Sears model number for me to help you better. Sears numbers look like this 213.235698 for example. Give me more about what is happening and where the sounds are coming from and if there is changes in the cooling. Sea Breeze
Posted on Jun 24, 2009
SOURCE: Samsung side by side refrigerator not working
I am somewhat of a fix-it guy and here is my take....I also have the same refridge with other problems, and have done alot of research and discussions with the local repair techs and Factory rep. Here we go: The Samsung models are very prone to problems arising from power fluctuation's that fry the motherboards. One problem may be that the defrost circuit fails and the unit freezes up causing a lack of cooling and loud banging of the compressor. To run a diagnostic of the unit, you need to press both power freeze buttons for 10 seconds beeps will sound and release, the dashes on the display showing if any circuits are bad.(self diagnostic) This is what the service guy will do then come in with the part and replace. With a bad board, the diagnostics reveals no problem and the service agent will just start replacing parts, at your expense! Also the part #'s will show discontinued but they just changed parts #'s.. Be careful, my dealer said all parts were no longer available....he was wrong! Motherboards are a bear, I believe my model has 3!Most techs are not familiar with Samsung and will not be able to correctly diagnose the problems, mine came out and said it! "We do not Know and the factory will not give us any idea what the problem is" We're sorry! That was 3 month ago, and now I have a beautiful yard fixture! a $1400.00 yard fixture!! hope this helps someone..
Posted on Sep 06, 2007
  • 1462 Answers
SOURCE: Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Posted on Jul 18, 2008
SOURCE: whirpool Refrigerator Making Loud Noise
pull fridge out and listen if noise is comming from compressor or not. If not, then your evaporator fan is comming into contact with the ice from the evap.coil. Basically give unit a good overnight defrost with doors open as the insulation on this fridge is good
Posted on Aug 18, 2008
ssebata paul
  • 159 Answers
SOURCE: making a loud moaning noise
remove from supply for 30 min
Posted on May 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: My Kenmore refrigerator is making a loud noise
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Posted on Nov 19, 2009
How to stop the really loud noise on my GE Refrigerator?
It sounds like the compressor is failing, I would make a service call soon.
Sep 23, 2016 | GE Refrigerators
My bosch is making a loud noise
I would call bosch directly, they have ppl that can help over the phone with some things.... Bosch is hard to work on so if you need service I would go with who ever Bosch recemends..... ken
Sep 29, 2014 | Bosch Refrigerators
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Whirlpool top-freezer refrigerator makes loud noise
Do you think it is the fan in the freezer or could it be the water valve when the icemaker is filling?
Nov 27, 2012 | Refrigerators
Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Sep 12, 2009 | Magic Chef CTB1821AR Top Freezer...
Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Aug 03, 2009 | GE Refrigerators
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator fan running but not cooling, making loud noise
Shayon, what is the model number? Maybe I can help you out. Scott
Jun 02, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
350 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
