Question about Brother HL 1440 Laser Printer
Just installed a brand new $164 drum and the drum light is still blinking
  • 526 Answers
You either have a service call error or you did not reset the drum
the instructions came with drum.
Posted on Jun 26, 2009
M2 konica minolta 164
replace the developer and the drum, ensure counters are cleared first before removing the image unit. ensure F8 is run after install no print or faxing rec until F8 is run or start over with new developer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 12, 2014 | Konica Minolta Office Equipment & Supplies
Konica mintola bizhub 164 maintainace call (M2)
replace the drum and developer and clear the counter also ensure you run the F8 after developer been replaced and new drum are installed
Mar 25, 2014 | Konica Minolta Office Equipment & Supplies
How to reset drum ineo 164
Does the screen on the control panel state to replace the drum? if so reset the counter with out replacing the drum is not good since the copier works off the counter if the counter is reset then the copier thinks the drum is new set the voltage for a new drum the voltage is set for a new drum which it is not causes image problems.
Dec 12, 2013 | Minolta Office Equipment & Supplies
Hi, we have the hp color laserjet 2840 series and we are getting a supply error (10.1004). The picture shows that there is a problem with our imaging drum. We bought a brand new imagind drum and it is...
Reseat the toner cartridge. Turn the printer off, and then back on again. You may want to try a new cartridge, but if that does not eliminate the error, call your HP support line. If the imaging-drum light is still blinking but the Attention light is not on, you must replace the imaging drum before the printer can continue printing. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition. The printer has determined that it cannot read or write to the e-label on the imaging drum.Reseat the imaging drum, and then power cycle the printer. If this does not work, replace the imaging drum. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on. If the problem persists, replace the imaging drum E-label reader. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition.
If Hope that this helps,, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks,Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 04, 2011 | Office Equipment & Supplies
Brother 5250dn drum light blinking; I think drum is ok because I put drum from another working printer and the drum light continued to blink.
The drum light is on due to a preset counter to notify you that the drum has reached the end of Normal Usage life expectancy. It doesn't mean that it has failed, yet...but soon. I would suggest having a new drum on hand for when print quality starts failing. Either new drum units have a reset fuse in them to clear the warning light, or there is a reset proceedure to use after installing the new drum unit.
Nov 06, 2009 | Brother HL 5250DN Laser Printer
"CH" is blinking
CH is a door open?Open side door before you open the front door,check that drum,dev & toner unit is installed if this doesnt solve it push the righthand door downwards so that the switch makes connection.
Aug 18, 2009 | Sharp AR-164 Copier
Error light and Drum light are blinking. Do I
Blinking says to replace drum soon, when it's on solid, it's time for a new drum...
Aug 04, 2009 | Brother HL 2140 Laser Printer
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
Sharp al-1551
Did you replace the drum with a Sharp brand drum? I recently replaced a drum in my Sharp AL-1642CS, the replacement drum fits ok, and the lights you describe are gone now, but it does make an annoying noise that is new. I wish I would have spent the money to get a Sharp drum, then you can call them directly for support. When I have called them they have been very helpful.
Dec 14, 2007 | Sharp AL-1551 Laser Printer
Kenmore 48106 brand new
they probably for got to remove the yellow brace in side the unit that holds the drum during shipping
Nov 30, 2007 | Kenmore 44042 Front Load Washer
Brother HL 1440 Laser Printer Logo
113 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
