Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front loader). The washing machine part of it works well, but when using the drier the clothes seem to have a odour that smells like hot rubber
  • Anonymous Nov 06, 2007
    My housekeeper dryed a rubber backed rug and left it going until I returned home. The dryer now smells like rubber and I know this is the cause of the problem. I've sprayed Febreeze on dryer sheets and nothing is helping.
  • tucker1929 Feb 19, 2008
    LG Tromm dryer model dle59775s just passed the one year warranty period. dryer got very hot (burning hot) on a "freshen up" cycle and undetermined smell - could be a rubber belt burning up or just the burning hot metal ? anyone else encounter this ?
I have a suggestion.
If you dry with Dryer sheets, the little downy felty waxy feeling sheets that make your clothes smell artificially fresh. If so,, clean your lint tray.. really clean it, try first running water over it and see if the water pools or not. If your filter looks clean but the water pools, than that means the dryer sheets have built up a waxy film that is very hard to see and there is not proper air flow, that could cause the dryer to heat up. scrub the lint filter with a little toothbrush, hot water, maybe a little suds.. It'tt also keep your house from buring down.. thank Downy.! :-)
Posted on Feb 06, 2010
    Problem Solver:
  • 16 Answers
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Posted on Jul 02, 2009
What is the bruning rubber odor - new dryer!
Im not familier with that particular machine but it sounds as though bits of the rubber backing you talk about has flaked into tiny bits and moved beyond the drum and into the workings of the dryer moter and heater. Contact with these will produce the smell and slight risk of fire.
The back of the applience will need to come off and cleaned out.How you accomplise this is up to you!!. If you have some one who is very handy at this sort of thing then grt.otherwise leave it to a proffesional. Obviosly compressed air gun is the way to do it.
Oct 15, 2013 | Maytag MEDE201YW Electric Dryers
I just purchased a new wheelchair and the tires are giving off a strong rubber odor. Is there anything that will correct this. We are going to be traveling and it will be in the car and the odor could...
Usage and allowing it to air out is about all you can do at this time. You can try washing the tires with warm water and a mild dish washing liquid rinse and allow to dry. But, I'm not sure, how much odor that will dissipate. It will probably help a little though.
Thanks for choosing FixYa.
Sep 22, 2011 | Health & Beauty
There is a burned odor when drying my clothes. How do I get lint from inside the dryer out if this is a problem
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 20, 2011 | Miele Novotronic T1515A Electric Dryer
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
My whirlpool gas dryer is taking twice as long to dry clothes. I cleaned all vents and filter and also ran it with the exhaust vent disconnected and dryer still did not dry any faster, but there was a...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 25, 2010 | Whirlpool Dryers
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Indesit gas cooker, odd smell
Indesit Cucina cooker
My tenant is complaining of burnt metal or burnt rubber smells when the oven is hot, it is perfectly clean and only two years old
Nov 26, 2008 | Indesit K344GX Gas Kitchen Range
Door inside and metal vent area smells strongly of fumes
Did you find an answer toyour question?
My microwave smells also of petrol in the same areas.
Jun 05, 2008 | GE JVM1653 Microwave Oven
A few things could be going on here. If you are hearing metal on metal sound I would start with the blower wheel itself. Sounds like it either came loose from the motor shaft or it's broke. Other things could be a bad drum roller that has frozen up causing the rubber smell. Your idler pulley could be frozen up and the belt is slipping on the drum. Go to this link http://www3.sears.com/ and post your model number to get a breakdown of your dryer. It wil show the areas I mentioned. Catriver..post back.
Feb 10, 2007 | Kenmore 63102 Electric Dryer
Washing Machines Logo
302 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
