Question about Plumbing
Fountain pump keeps tripping the GFI
I have tried numerous electrical outlets for my fountain pump and it will sustain other things like fans and lights, but when we plug in the fountain pump, it trips the GFI and stops. Why is this and what can we do to solve it?
  • Tony Crow Mar 20, 2012
    your pump id grounded and tripping , check pump and wiring for leaks ,
  • 4 Answers
Install a standard outlet with a weather proof box and you will have no more problems
Posted on Jun 26, 2009
Pump keeps tripping gfi outlet
That means the GFCi is doing what it supposed to do...shutting off the circuit in the event of a fault. Repair or replace the pump. You can plug something else into the GFCI to test the outlet itself
Mar 21, 2012 | Little Giant Water Wizard 5msp 115v 60hz...
Are pump keeps tripping the mains electric it only works for a few minutes until this happens
Do you have the pump plugged to a GFI outlet (with the "reset button"). If not, you should. If you do, that circuit must be overloaded, try using an outlet that is on a different circuit or moving other things off of that one, depending which is easier.
Jun 28, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Our hot tub keeps tripping the gfi breaker, but if we don't put it on a gfi then it works fine. How do you fix this
The GFI is sensing a fault, and tripping to protect you. If there is another GFI in the circuit somewhere then you could use that normal receptacle. I mean if there is a GFI in the main panel.
Please Vote !!
Apr 19, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have a 302 in a wall fountain that has stopped working. I am not sure what the little lever controls or which way to turn it. Having guests soon so need to have it working. Thanks in advance.
check to make sure you have power going to it, i.e., the outlet where it is plugged in has power and the GFI is not tripped. Also check to see that the impeller is not clogged or has some sand lodged in the impeller. If those things are ok, your pump may be bad. the lever should only control flow and should not stop flow completely in any setting.
Dec 02, 2009 | VIA Aqua Pump 4900
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
The Ebara EPPD 3MS1 pump will trip the GFI breaker on the outlet
Will the Gound fault socket (outlet) support the current rating of the pump
is the outlet wired correctly where the return wire is in the correct spot and the high and ground is correct not switched around?
Does the pump run in a standard outlet?
Test it with a heavy duty extention cord if no standard outlet socket is nearby?
Is the pump shaft dragging putting an un necessary load on the motor?
Aug 02, 2009 | Ebara EPPD-3MS1 PRO-DRAINER Manual Sump...
The pump seems to be tripping the GfI outlet and the problem is not the GFI
It's leaking 'current' and the GFCI can sense it. Dry pump out thoroughly and open it up and see if it's wet inside. Needs to be dry and reseal
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 15, 2009 | Leader 5000 Solids Handling Bvp Pump
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Kenmore 80 - in mid spin cycle the machine tripped GFI
check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Beverage air dd78 comp.wont start..tripping GFI
Refrigerators often will trip the gfi via the compressor. If you have checked all the wiring. The problem is likely in the compressor windings. I have had this occur in brand new units. Another thing to check the gfi, less expensive gfi outlets do not handle refrigeration equipment well. You should consider getting an industrial rated outlet. Hope this helps.
Oct 22, 2007 | Beverage-Air Beverage Air 2- Tap Unit...
Plumbing Logo
733 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
