Question about HP Photosmart R707 Digital Camera
Card Locked When camera is turned on, the display shows card locked. Pictures are not saved. Unable to format the card as well. Tried new card. Same problem persists.
  • 1 more comment
  • Anonymous Nov 27, 2007
    card cannot be formatted.  Cannot take pictures to card.  Have  inserted several compatible cards
  • JRBear Jan 22, 2008
    Card really is full of pictures. Camera says "LOCKED" but the tab on the card is not in the locked position and never has been. Removed it, moved tab back and forth, left tab in UNLOCKED position and when inserted, camera still says "LOCKED".
  • hawk123 Mar 08, 2008
    I have the same problem with my HP Photosmart R707 camera. I did an online chat with an HP tech and we formatted the SD memory card on the computer. Put the card back in the camera, and still had the Card Locked message. Tech said the memory card reader inside the camera was defective and suggested a new camera. I'm wondering if there is a better solution to this (software fix). Funny thing is that the camera was working fine two weeks ago with the same memory card!
Remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Posted on May 21, 2008
  • Heather Koffler
    Heather Koffler Oct 12, 2014
    nice one there.... never noticed the little tab on the side of the card!~ thank you!!!
How do I unlocked the card on my HP R707.
When I turn the camera on the message I see is: card locked
Posted on May 08, 2008
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures.
Dec 22, 2013 | Nikon D3000 Digital Camera
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
Okay the card is not locked I'm adding a diagram anyway. The next thing is did your format the memory card in the camera in which it is to be used? If you have just installed a new memory card it needs to be formatted. Or have you downloaded pictures from the memory card to the computer? Did you format the memory card in the computer? Did you unplug the camera or card reader without doing a safe disconnect? These are all reasons why you need to format the memory card.
Diagram just cause I have it on speed dial
Jan 21, 2011 | Polaroid PhotoMax PDC 4055 Digital Camera
My new t21 display said "unable to access card" my
If you are using the camera to download pictures to the computer you should be able to set around this problem by purchasing a card reader. These plug into the USB port and the camera SD card plugs into the reader, the computer then loos at the SD card as an external Hard Drive. Create a new folder in ? "My Documents" transfer the files from the camera memory card (copy past) into the new folder and you have your pictures not on the computer hard drive.
Do a "safely remove" "eject" or what ever language you computer uses to shut off the connection and disconnect the memory card from the reader.
Format the memory card in the camera always format the memory card after downloading pictures to the computer and always make sure it has completed the download and you have turned off the feed.
Failing this your do two things corrupt the card and possibly the camera software.
Okay another thing that the SD card have is a lock I'm giving you a diagram to see and make sure the card is in the write position.
You should be good to go
Jan 20, 2011 | Canon EOS Rebel XSi Digital Camera
Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Jul 23, 2009 | Canon PowerShot A590 IS Digital Camera
HP photosmart m525 camera.....card is locked
Please try to format your card on computer and then use it....
May 29, 2009 | HP Photosmart M525 Digital Camera
Memory Card Locked
There is an option to lock the memory card, so here's what you do. Open battery slot<remove card<there is a lock tab just switch it to unlock. tab is on side of card on SD card
Dec 08, 2007 | Samsung Digimax D53 Digital Camera
maybe if you reset the cam and card, by formatting it using the PC rather than the Camera, save what pix u can then format, to format, goto my computer right click camera drive, usually F:\ press format, do a full format, dissconnect from PC then make sure u leave power on and format thru the camera, dont know if its possible top save pix but this shud fix the whole card issue
Jul 27, 2007 | Vivitar ViviCam 5100 Digital Camera
HP Photosmart R707 Digital Camera Logo
325 people viewed this question
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
