SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
SOURCE: fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
SOURCE: On our Fisher and Paykel, the spin cycle does not
what modle do you have how old is it does it power down and turn off or does it stop and start beeping at you have you tried it with no clothes in it and if so does it do it then , these machines are very simple as they have vert few machancal parts post a phone number and i will call you
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
