Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
1997chryslerlhs#1cylindermisfire changed sparkplugs and wires engine runs good on acceleration engine runs rough when idiling in gear and in park
    President:
  • Jeep Master
  • 1,114 Answers
I'm not a mechanic by any professional means but, it sounds like a vacuum leak to me. Check your lines. If this is a vehicle you are going to keep a while, go to www.alldata.com you can purchase a subscription to the "manual" on this vehicle which includes all dealer bullitins, common problems etc. It's an awesome tool! I paid 24.00 for my first year and 16 to renew. So far saved thousands!
Best of luck! Hope this helps
Posted on Jun 24, 2009
Have a 1990 cadillac deville engine runs smooth in park/,neutral when iput in gear and accelerate it shutters changed plugs / wires no help could it be tranny or cv joint no noises from either
Does idle rough in gear if so may have bad fuel injectors. not saying that it is not transmission or joints, need to make sure the engine is running properly first.
Nov 12, 2014 | 1990 Cadillac Deville
What causes bad gas mileage stalling at high speeds and rain idiling rough engine knocking 2003 Isuzu Rodeo
Check the coils, there may be a bad coil. That lets moisture in it, and causes the engine to mis fire. God-Bless! Its worth a try!
Oct 06, 2017 | 2003 Isuzu Rodeo
Tuned up car changed 02 sensor full tank of fuel still running rough
Oxygen sensor only report the condition of the engine the rough running condition can range from a worn sparkplug wires to worn sparkplugs to valve problems to injector problems. with the cadillac deville a tune up should be the first attempt to smooth the rough idle with the inspection of the cap and rotor cap and rotor do have a tendancy to arc internally and create misfire so does sparkplug wire that can leak spark voltage to ground and create misfire. the spark plug wire especially if they are brittle and hard can create issues
Apr 23, 2011 | 1990 Cadillac Deville
Lost of acceleration power, no power going up a slight incline. however in park engine runs a little rough, but will accelerate but when put in drive has no power
This may be caused by a misfire, this can be caused due to a tuneup, have the plugs and sparkplug wires checked, also is the check engine light on? if so scan the codes, many autopart stores will scan for free if there are misfire codes then i would start with a complete tune up and go from there, the most common problem when this happens is a tuneup is needed or the fuelpump is weak, to test the fuelpump you will need to have a pressure tester put on the fuel rail, hope this helps. good luck.
Nov 10, 2010 | 2002 Saturn VUE
Was driving down son's dirt road driveway returning home at low speed in 2nd gear in my 1997 sunfire when it suddenly started running rough with no power. it will start right up and idle is rough but...
Sure sounds like a typical case of dirty/contaminated fuel....or a broken vacumn supply hose around the intake manifold area, in neutral let it idl;e and look and listen for a hissing sound, or a broken black rubber hose.
Also have the computer scanned for any possible codes.
Another thing to look at is the catalyctic converter, put a vac. gauge on the engine and see if the vac drops to almost zero...indicating a plugged cat.
Aug 07, 2010 | 1997 Pontiac Sunfire
When putting van in gear the engine runs rough
how about putting the van in drive with one foot down hard on the brake and rev the engine, does it smooth out now? if it smooths out, i would pull the air cleaner tube to the throttle body and spray the throttle body with carb cleaner, be careful if using the red tube, I have had it blow off before into the intake, not good, open the accelerator and spray it out really good, it will to start until all the cleaner clears out.
Jun 29, 2010 | 1995 Pontiac Trans Sport
I have a 2008 Dodge Avenger and the check engine light is blinking, also the car has a rough ride when I go from stop to acceleration.. What could this be
sounds like your have a misfire in one of your cylinders...a flashing check engine light with engine running rough. Check your sparkplugs and wires. you should have the code scanned.
Jan 06, 2010 | 2008 Dodge Avenger
Engine missing Have to change sparkplugs every three months to stop problem.This is not normal what is the problem 2000 ford range 4.0 119,000 miles.When I accelerate the tranmission change the engine...
First replace oil and filter in the transmisson next replace the spark plug wires and coat both ends of the wire with dielectric greese this should eliminate your problems. Also do a top engine clan to get rid of carbon build up and clean te throtle plate front side and back plus the port hole the plate is located in. Whith the throttle plate not fully closed it allows unburnt fuel to be depostied on the plate and causes it to run poorly.
Nov 01, 2009 | 2000 Ford Ranger SuperCab
Car Audio & Video Logo
56 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
