It is located on the left side of the front of the motor. Lift the hood, look at the front left side under the air intake (big black pipe connected to the filter box in the front left behind the headlight). You should see a 90 degree angled metal housing with a black hose coming off of it. Where the metal housing connects to the front of the motor block is where the thermostat is located. To access it / replace it your will need to remove air intake host and then the bolts on the metal housing. It will be messy - coolant will leak out so have some rags and a pan under the motor or drain the radiator some before pulling it off. Also - obviously make sure the motor is completely cooled down and the battery is disconnected before working on it.
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on
Saturn
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
