Question about Frigidaire FRS26R4A Side by Side Refrigerator
New refridgerator can I plug it in now?
I bought a new fridge today and had to transport it on it's back for about an hour. it has been unpacked and upright now for about 5 hours. Can I plug it in now? Thank you!!
  • 351 Answers
Yes you can but boy i would not recommend doing that again, not good to do that to refrigerators
Posted on Jun 24, 2009
Why are the sides of my new Samsung RT22FAJBDSA (8.3 cu. ft.) Ref was so hot although the inside was cool?
Did u follow the unpacking and installation instructions??
Are the sides,bottom,and back of refrigerator clear of all obsticals?
Did u remove the plastic from the ac cord prongs?
Sep 22, 2014 | Refrigerators
I got a new mini fridge and when i got it home and plugged it in it didnt work at all
Uhhh ohh
did you set in on side when transporting it home? if so the oil ran out of the compressor and now the compressor is shot
best advice i can give you is return it to where you bought it and exchange for new one
IF YOU PUT THIS ONE ON ITS SIDE LEAVE IT UPRIGHT FOR 48 HOURS BEFORE PLUGGING IT IN SO THE OIL WILL DRAIN BACK INTO COMPRESSOR
Jul 30, 2011 | Refrigerators
I have a stainless steel Amana model ABC2037DES that was given to me. It has been plugged in for 24 hours and it is not freezing anything or making ice. The refridgerator is not cold enough either. ...
if the compressor is working it could be a thermostat problem
I think that if you check for a reset button at the back to get the compressor running , that will fix the problem
Mar 13, 2017 | Amana ABC2037DES Stainless Steel Bottom...
New fridge coming today...
Good day,
If it's being delivered by an appliance company, they know that the machine has to be transported upright. So no. You should be able to plug it in as soon as it's set up.
IF the machine is transported on it's side, then yes, a minimum of 24 hours is necessary to get the oil back into the compressor.
Jun 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Just bought a new whirlpool top freezer fridge. Waited 4 hours then plugged it in. 30 hours later food is still not cold enough and fridge continues to run. Will it get colder, am I not giving it enough...
If you transported the fridge on it's side you may have drained oil into your lines, causing excessive head pressure. If you haven't unplugged it yet, please do it now and allow 8 hours for the oil to drain back to the compressor. If you are lucky, and the fridge didn't run too long and burn up the compressor, you should be able to come up to temperature with no trouble.
Mar 09, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
New refrig deliverd today told not to turn on for 2 hrs to let gas settle as it reduces the lifespan. true or false.?
False . If it was delivered laying on its' side , back , or front , 24 hrs is necessary . If delivered standing up , no need to wait .
Nov 13, 2009 | Belling BE808 Compact Refrigerator
Can I transport my brand new Whirlpool on it's side?
It's certainly not recommended because you can fill and clog the refrigerant lines with oil from the compressor.
IF YOU MUST...your chances are better if you leave it upright for an hour or so before plugging it in. This allows the oil to drain back into the compressor. This period should be appreciable longer in cold weather as the oil is thicker.
Sep 12, 2009 | Whirlpool Refrigerators
Bought this model from someone new, it was working great when I checked it out, transported it to our house and plugged it in the next day. Freezer works well but fridge barely cools at all. Any...
HI There,
If it was transported to to your house not in an upright position, then you may need to unplug it and wait for 8 hours to have the fluids settle before starting it again. If that is not the issue, ensure that there is ample space at the back of the unit, between the wall and the fridge to help circulate the air. Inspect the coil found at the back of the freezer for ice build up or dirt. If there is let it melt and have the unit cleaned out first before restarting.
Aug 22, 2009 | Refrigerators
Can I transport a whirpool side by side refrigerator / freezer, laying it down on it's side for 5 hours?If when I reach my destination I stand it upright for 48 hrs. before I plug it in.
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Jul 17, 2009 | Dometic RM2193 Compact Refrigerator With...
Kenmore refridgerator c1065094881
It sounds like your defrost cycle has stopped working. unplug your fridge for 24 hours and let it defrost. plug it back after 24 hour and if it starts to cool in the fridge part at about 40 degrees F. you will have to replace one of three parts the Defrost Timer, Defrost Themo or Defrost Element. I hope this helps you.
Dec 22, 2007 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
211 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
