Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My macbook wifi card connects sometimes and not others. It is always cutting out at inconvenient times.
  • Apple Master
  • 4,338 Answers
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:Mfg. suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the router may cause conflict with other routers within your network range. Mfg. suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 24, 2009
Printer suddenly stopped communicating w/Macbook Air. No red light. Same connection always used. Unable to send data to printer
Try plugging in via USB cable. If it prints fine it may be a wifi card in the printer if you having no other connectivity issues with your macbook.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Jan 18, 2016 | Office Equipment & Supplies
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
WPA for Apple MacBook pro
Mac computers have always been known by being stubborn in wifi matters. Please try the basic steps, like reset SMC, most of the times it sorts this issues. If problem persists and you have access to the router, make sure you have WPA2 Personal AES.
Reset SMC:
Intel based Macs Resetting the System Management Controller SMC
To read more about the best WIFI settings for your Mac:
iOS and OS Recommended settings for Wi Fi routers and access points
Hope it helps,
Alex
Sep 05, 2014 | Apple MacBook Pro Laptop Computer with...
I have a MacBook Air and to use wifi I have to sit directly next to the wifi router. All other macs/iPads etched in the house are fine. Hardware or software issue?
Most certainly a hardware issue. The MacBook in question probably has a connectivity issue. What solutions have you tried thus far?
Jul 10, 2014 | Computers & Internet
Only one device is having internet issues
Have you checked the IP settings on your internal network. It sounds like you have 2 identical IP numbers.
May 29, 2017 | D-Link DIR-615 Wireless Router
Lost wifi connection
Macbooks can be a bit finicky with their Wifi depending on the model number, and also which router you have. For example, an old Netgear-based router I had would routinely drop the connection to my old Macbook Pro, even though the mac had nothing wrong with its hardware or software, and it would still think it was connected perfectly to the internet.
The easiest way to determine if there is a problem with the Wifi built in to your mac is to try it on another network and see how you get on.
If you have no problem keeping connected on an alternate network, the issue lies between your computer and the base station, and is probably also affected by any other wireless networks you have close by.
At this point, without knowing anything about your router, I wouldn't want to suggest anything more, though forcing your router to use a particular Wi-Fi channel rather than allowing it to choose it itself might help out a lot. It's probably best to ask a local technician if they can help out if you're not comfortable changing such settings.
Nov 29, 2013 | Apple MacBook Pro Laptop Computer with...
I keep losing my wifi connection
try reseating the wireless card or airport card. if that doesnt work. turn off your wireless router and your macbook. leave off for 10 mins then turn on the router first then macbook. try to connect and see if that fixes the problem.
Dec 19, 2012 | Apple MacBook Air
I have an old PowerBook g4 in my kitchen for listening to pandora and looking up recipes. All of a sudden, the wifi stopped working. It has dropped out a few times before, but I have always been able to...
Cut the airport off and back on again. After that, delete any wifi profiles you have, and then re-add them. This will clear any corrupt profiles and troubleshoot that. If you can't connect to anything after that, check that the airport card is connected securely. If, after all that, it still isn't working, and other devices are able to connect to the same network, then your airport card is probably no longer working.
Nov 09, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I couldn't use WiFi in my 2009 MacBook Pro. I check it from System Preferences but it looks like I don't have any WiFi card. Just Ethernet and Firewire etc. I re-installled Snow Leopard but it isn't a...
Sometimes performing a PRAM reset on your laptop will sort out WiFi and Bluetooth issues.
Restart the computer, and before the grey screen appears, hold down the Command(?), Option, P, and R keys simultaneously. Keep the keys down until the computer re-boots again and you hear the startup chime for the second time. It should work after that.
May 04, 2011 | Apple MacBook Pro Notebook
My toshiba notebook with part number pslu0u-02u002 there's a problem the connection on wifi. Sometimes it can't connect to the router even there's a signal of internet because my room mate his computer it...
remove wireless driver and remove the wireless card, power on , shut down, plug the wifi card and install driver, press the wifi on off short cut key or switch when you need to go internet
Sep 28, 2017 | Toshiba Satellite L505ES5015 NoteBook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
940 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
