Question about Dell Dimension 8200 PC Desktop
Cover to usb port wont close - Dell Dimension 8200 PC Desktop
  • 2,229 Answers
To fix this, you'll have to take the case apart--the plastic guides have apparently come out of place in the case.
You may be able to put them back in place, but it will be a tedious job just because you have to take the case apart.
Posted on Jun 24, 2009
    President:
  • 3,278 Answers
Open up the clamshell case and see if something is jammed at the rear of the front cover.
  • NinaE Jul 02, 2009
    Was this helpful ??? Resolve your problem ?? Thanks.
Error message usb ports force stopped because of too much power
It will still be covered by the warranty, take it to an apple repair centre, they will have Apple hardware diagnostics software that will be able to determine the cause of the fault. Worst case scenario will be they have to replace the logic board.
If you are using some sort of USB hub the number of devices you are connecting to that single port may be drawing too much power. Try to determine how much power each device is drawing then ask at an apple store how much power the USB port can supply.
Feb 22, 2014 | Apple MacBook Mac Notebook
I had just gotten my usb that i wanted to plug into so i can transfer some items from my Xbox360 to my computer but then i noticed that the last time i had taken out the wired controller it took part of a...
The USB port is likely broken for good. However, you can buy USB hubs like this one that take one USB port and splits it into four. They're also really cheap, that one being around $3.
Also, if you only need two USB ports, there is a third one in the back of your console, right above the network port.
Apr 16, 2011 | Microsoft Xbox 360 Console
Where do you plug it in on the camera
What you are trying to plug,USB cable external microphone?
For USB cable normally the ports are located on the sides of the camera and have the USB symbol on the covering cap.If external microphone or flash check for the top metal shoe
Mar 31, 2011 | Cameras
The lens on my samsung s860 will not close (pull back)
Please disconnect the web cam from the USB port. Look for any particles on the lens cover. Insert the cam to the USB port again. This time it will close. If not, un-install and reinstall the device driver. This will definitely solve your problem.
Mar 22, 2011 | Computers & Internet
Cannot get mouse to work
1.
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
3.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
5.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
6.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
Player wont connect to computerr via usb port
mp3 player is not connect to computer via usb port
Sep 19, 2009 | Audio Players & Recorders
Need to fix urgently lexmark x3470 cover open error. in images if possible.
open operator panel (top piece with electronic display) lift up cartridge cover (the one you lift to change cartridges) there is a small black plastic lever which you can manually move up and down with your finger (usually on left side). take a piece of tape and TAPE IT DOWN so that it can not pop up again (popping up is what triggers the error message (cover open) even when it is closed.
after you tape it down you will never see this error message again, even with the cover up.
who needs a machine to tell you a cover is open? we can SEE this with the human eye.
it is a useless feature. also, check device manager (com ports) to make sure there are no yellow explanation marks (port error) or no printer will work on it. you may have to make a change in bios to assign the port manually to make sure there are no conflicts with the port. nancynerd
Jan 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
USB connector problem
It shouldn't be a problem. Check the SwimP3 V2 FAQ website. It says:
Q: The cap that covers the USB port on my SwiMP3 came off during my swim, will this damage my player? A: No, the SwiMP3's USB port is completely waterproof, the cap is there to keep the USB port generally dry so you wont have to dry it by hand before connecting it to your computer.
Oct 30, 2008 | Finis Swi MP3 Player
Camcorder Will Not Close
This is due to the improper closing of the cover below the cassette compartment(where the USB, 3894 ports r there)
Pl. close it properly. Then open the cassette door completely, and then close. It works.
Dec 07, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
SanDisk Sansa cover
I think everyone has that problem. Poor Design!!
Oct 15, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Dell Dimension 8200 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
