Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Card Locked The camera says "card locked" however the memory card is not locked. I've switched out the memory card and still does not seem to work.
  • Canon Master
  • 4,738 Answers
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
Memory card is in the unlocked position but the camera still says it's locked
Posted on Jul 20, 2009
4 Suggested Answers
SOURCE: Memory card locked
Hi everyone,
Here's the solution, I just had the same problem LOL!
1. take the memory card out
2.On the memory card there is a little switch (it will be the little tiny piece on the side of the card thats a different color) slide it up.
That's it!
Bye
Posted on Jan 26, 2008
Bubbabear64
  • 2794 Answers
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Posted on Jul 04, 2008
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Posted on Dec 13, 2008
I got cannon power shot sx130 is it reads memory card error the memory card is not locked but the eject button is not working how to fix this problem. thanks
Try to switch off the Camera and restart it gain. Again, Sometimes, its due to some auto-run software running in the card which prevents that from ejection. You can try to even format the card in the camera itself. That may work also.
As a last resort, check up your camera and get that memory card removed out of your Camera.
Feb 16, 2015 | Canon Powershot SX130IS Black Digital...
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Camera comes on, says card is locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 14, 2013 | Casio Exilim EX-S5 Digital Camera
My memory card for D3000 is locked but i checked the card, it seems like the lock is not there how do i sort this out?
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D300 Digital Camera
My card is locked
Look at the memory card. SD and SDHC cards have a small slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 15, 2012 | Samsung ST45 Digital Camera
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Card locked, have tried the slide on the card...no help. Bought a new card, same results
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. And finally, if the cards that you've been using are 4GB SDHC, that's your problem.
Jun 13, 2011 | Canon PowerShot A630 Digital Camera
Canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Dec 18, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Jan 01, 2008 | Samsung Digimax S630 Digital Camera
Memory card locked
Hi everyone,
That's it!
Bye
Nov 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
242 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
