my optoma h31 projector in my basement does not turn on at all, no lights come on or anything.Could that be the lamp, it didn't have over 1000 Hrs. I did not use it for 10 month.
It can have two problems. One is that the lamp has gone out and needs replaced. Refer to your troubleshooting section in your manual. Also can be bad capacitors in the power supply circuitry or Voltage Reg. IC. Either should be left to competent repair individual.
have acer xd 1170d projector and can't get into menu it will not display and will not reconize...
(More)
have acer xd 1170d projector and can't get into menu it will not display and will not reconize anything that is plugged into it. i have only used a dozen times bought as new thank you cheers greg
I have my Optoma h31 hooked up to my macbook, but when I switch input's it says "no...
(More)
I have my Optoma h31 hooked up to my macbook, but when I switch input's it says "no Signal". Any Ideas?
the system was working great we turned it back on and the vertical bars apppeared and the color went...
(More)
the system was working great we turned it back on and the vertical bars apppeared and the color went mostly green shades any ideas ??
my optoma h31 projector does not turn on at all, no lights come on or anything. It does have over...
(More)
my optoma h31 projector does not turn on at all, no lights come on or anything. It does have over 2000 hours on the bulb, but was working one minute, I took it down and moved it to the other side of the room and it wouldn't come on. I tried a replacement power cord and that didn't work. Could it be the bulb or is it fried?
