Home | Ruud | 5.0 Tons 12 Seer Split Central System Air... | Ruud Gas Hot Water Hea...
Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Ruud Gas Hot Water Heater Shuts Off
By mawills1 on Jun 24, 2009
Ruud gas hot water heater shuts off and needs reset multiple times and will only run continiously for less than a day.
Solution #1
posted on Jul 04, 2009
Not Rated)
daddyo742001
Rank: Guru
Rating: 86%, 23 votes
If this is a hot water heating system for home heating It may be thermocouple of flame sensor. If it has a sensor rod in the flame check and make sure flame is hitting it. Also a little sand cloth to polish it may do the trick. I have to due this to my gas furnace sensor every couple of years. If this unit has a pilot light and it is weak and yellow verses strong and blue it may need cleaned. Some times you can tap on it while it is burning and it will dislodge plug. If it A domestic hot water heater for washing and such the above still holds true. If polit is strong and hitting thermocouple then replace thermocouple.
Was this helpful?
Yes
No
Solution #2
posted on Jun 29, 2009
Not Rated)
co7196
Rank: Wiz  Air Conditioners  Expert
Rating: 85%, 1011 votes
Sounds as though your thermostat isat fault.,
Was this helpful?
Yes
No
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
when this happens i open up the unit outside & there is only one test light flassing. i have to... (More)
Answer
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud 5.0 Tons 12 Seer Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
