Whirlpool LSR5233EQ0 top loading washer wont spin
Tub fills with water but agitate cycle wont spin the spindle.
Manually turn control knob to rinse/spin and it drains but no spin
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupler that is more resilient and should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe, but the motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
Posted on Jun 24, 2009
  • 126 Answers
I'VE HEARD THIS SONG BEFORE FILL, NO AGITATE, DRAIN, AND NO SPIN. YOU HAVE A STRIPPED DRY COUPLING, WHICH IS A PLASTIC RUBBER COMBINATION THAT CONNECTS THE MOTOR TO THE TRANSMISSION. REMOVE SCREWS AND FLIP TOP CONSOLE UP. FLAT HEAD SCREW DRIVER REMOVE CLIPS AT CORNERS, DISCONNECT 2 WIRE PLUG. PULL WHOLE OUTER CABINET TOWARDS YOU AND PULL AWAY FROM MACHINE. LOOKING AT THE BOTTOM CENTER, REMOVE SCREWS HOLDING MOTOR CLIPS, DISCONNECT ALL PLUGS (HARNESSES) AND REMOVE MOTOR. COUPLING WILL BE VISIBLE AND PEGS/RUBBER WILL BE WORN, REPLACE AND REASSEMBLE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
My Washer does not spin or agitate when washing, but it spins when drying on cycle...
Hi Mate,
Check the controller, is it digital or analogue ( pushbutton or control knob that turns ) Sounds like part of the switching cycle has burnt out replacement of controler may be the answer
Stoker
May 11, 2008 | Frigidaire GLWS1233A Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
395 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
