Question about Goldstar R5050 Air Conditioner
I was wondering if you can install the air conditioner vertical instead of horizontal since the window is too small
  • 434 Answers
NOOOOO. The compressor in it is mounted and can only sit one way. If you install it sideways it will burn up the compressor
Posted on Jun 24, 2009
DISCHARGE GRILL -- is installed in factory to provide HORIZONTAL airflow. If a VERTICAL airflow is desired, the direction can be changed by rotating this. Most SLATS w/c allow change of airflow are broken...
dear sir/madam
as long as i know it,s hard to convert horizontal flow type of grill to vertical type of grill of air conditioner coz all window type of air conditioner is specially design for it,s desire model and horizentle type of grill there air flow come from top of aircon and vertical type of grill aircon design for side flow type of grill.it,s different to each other,
ifor more information please contact to this link .
http://friedrich.com/index.html
thank you
hope answer the question.
please vote!
Sep 23, 2010 | Friedrich WallMaster WS10A10 Air...
Window too small for a/c
Unfortunately you cannot mount this type of A/C vertically. The compressor must be in the upright position or it will be damaged and not function in a short period of time.
May 30, 2010 | Goldstar R5050 Air Conditioner
Wimdow Air Cond.
Sorry, that's a no. There are, however, window air conditioners made for casement style windows which are tall and narrow. I know GE used to have them. Check geappliances.com. There are also " portable " air conditioners which sit on your floor and vent through hoses to a window.
Jun 18, 2009 | Heating & Cooling
Vertical to horizontal
most all airhandlers have a second pan included . if not they can usually be purchased with directions to mount to the side of the coil for horizontal right or horizontal left application. remove the front panel and take a flash light look inside and you should see a cookie sheet looking pan on one side of the coil usually on the right side coil can usually be removed and reinstalled with the top of the coil facing the filter or the blower depending on how you want the air to go . just be sure the pan is under the coil and you will be ok . i have actually seen pros install them with the pan above the coil! and of course they flood the place. water of course goes down hill. the square donut pan used for vertical install stays in place as found. you will need to install a second emergency pan to catch any backup drips especially if you put it in an attic. you should find them at a sheet metal shop and they are basically a pan even bigger than the airhandler that catches any drip. it should be connected to a drain to the outside also and a float switch installed in case it fails to shut off the ac. better to get a no cool call than a flooded house call. try to put the second drain out over a door or window where it will be noticed before damage. good luck and remember you will have to relocate ductwork, electric drains filters refrigerant lines and if its in an attic a decked service area and a light and an outlet are required here in fla. good luckagain.
Oct 25, 2008 | Ruud Central System Air Conditioner
Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Goldstar R5050 Air Conditioner Logo
224 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
