Question about Harman Kardon DPR 1005 Receiver
Hey, my HK Dpr 1005 is a few years old now. It has been absolutely awesome. lately the centre channel speaker has had a hissing, static type noise comiing from it... I thought the center channel speaker blew...i went and picked up a new center channel speaker today and hook it up... same problem! Even with the sound turned right down the hissing/static is the same problem. I tried to see if it was my cable box, xbox, bluray, all had the same issues. I checked all the cables... they are fine too. it is just the center channel. When I set it to be 4 channel (all four surr speakers + sub) this hissing is not there... only when the center has a feed to it. The hissing stays the same loudness regardless of the volume of the unit. Have you heard of this before? What can I do? Thanks
  • jaison_reinh Jun 24, 2009
    i appreciate the last experts prompt response but in my original post I explained what the problem was and the trouble shooting measures I have already taken. He pretty much told me to do what I have already done...so that didn't help...anyone else have any ideas? Thanks.
    Thanks for your response.
    I understand that electronic equipment can have a hissing noise but I have had this HK DPR 1005 for three years and this has just come up in the last two weeks. The hissing noise is so loud on the center channel that if I have the volume at -42db (my normal listening level) I can't hear anything but the hissing/static noise.
    I have tried all the settings available on the unit and nothing has worked. I have never had a receiver before that one channel has failed on... does this happen???
    President:
  • 2,187 Answers
Normally for these sounds, it is unlikely that the speaker would produce the sound since it is just replicating what is fed to it. There could be a device producing
The hissing increases as you increase increases as well correct? IT may be the preamp stage. If is is relatively constant it could be on the power amp. Normally if these two are the problem all speakers would be affected. This may mean that the internal connections going to your center speaker from the amps is faulty.
Posted on Jun 24, 2009
  • Nicolo Carlo Parazo Jun 24, 2009
    Re-posting solution:
    could be a device producing the static around the area of the center speaker. If it is possible to isolate the theater system to rule this one out.
    faulty.
    Thank you
  • 10,515 Answers
I believe what you are hearing is a signal-to-noise condition caused bythe receiver's electronic circuits. Just about any piece of audioequipment, with few exceptions, will produce some type of randomhissing noise. It's inevitable, electronic devices produce noise, ofsome kind.
Few old receivers have have a switch to change impedance from 4, 6, or 8 ohms. Change in settings might help.
There is a good article :-
http://www.repeater-builder.com/rbtip/buster.html
WE NEED TO FIX THE ELECTROSTATIC SOUND.
Hope i helped you.
Thanks for using "Fixya".
    President:
  • 1,197 Answers
I would either calibrate it with a DB meter or check your reciever to see what gain your center channel is at..you might need to bring it down from the preset point it picked.
First, try another speaker on the same center channel. Swap it with another of the speakers that seem to be fine. That way you will be able to determine if the problem really is within the amplifier OR the speaker.
From above, you will know if you must repair the receiver OR the speaker connected to the center channel amp.
if its the speaker.... then the tweeter coils are the ones which might ve gone bad....
Test center channel speaker damage by connecting it to front main left or right and playing some stereo music.
Test the receiver center channel out by redirecting center channel audio data to the fronts.
Double-check your physical connections to the center speaker, too - something may be loose.
if all the above methods fails and if u found no problem with ur speakers.... its better u change the receiver....
kindly rate my service ... good luck
Whats wrong with my stereo
How old is your HK receiver? The power supply capacitors can get old and tired, and cause the hum and shutoff. Repair is an option.
May 03, 2015 | Harmon Kardon Harman Kardon AVR1600 50W/CH...
Sansui au-999 static right speaker then blows right speaker fuse
so meaning the right speaker needs a filter which frequency is it normaly u using a certain yf for a certain type of speakers and if you dont the fuse or what ever will go
Apr 15, 2012 | Audio Players & Recorders
Cause of a hissing sound from left front channel receiver
Recheck all of your connections and make sure they are ok. Also watch out for noise from the power supply and other electrical devices. Components with heavy power usage, fans or lazers
can create interferance. Run your speaker cables away from these sources. Also watch when bundling wires too many or the wrong ones togerther can cause this problem.
May 05, 2011 | Harman Kardon DPR 2005 Receiver
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
Intermittent crackling sounds DPR 1005
This is an obvious thermal problem. Use circuit cooler to isolate the bad part. It could also be a crack in a circuit board.
Alternate warming with hair dryer and cooling one component at a time while listening for the noise.
Feb 16, 2010 | Harman Kardon DPR 1005 Receiver
Static in speaker channel on my Samsung Surround Sound system
our started cracking and popping this morning. It seems from all the posts that it is always the right front speaker. With that kind of trend it can be traced back to mfg. Is there a recall, are they covering the cost?
Nov 11, 2009 | Samsung HT-AS720ST Theater System
Harman Kardon DPR 1005 problems
Sounds like the power supply or associated module. Definitely fixable, but probably needs a technician.
May 13, 2009 | Harman Kardon DPR 1005 Receiver
Static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Jan 28, 2009 | Harman Kardon AVR 25 MKII
RF channel is messed u
Problem is it is a common problem. I have one with the same thing, it appears as though HK discoed the line for a reason and sold them all at half price in Costco.
Mar 02, 2008 | Harman Kardon DPR 2005 Receiver
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Harman Kardon DPR 1005 Receiver Logo
165 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
