Question about Whirlpool Dryers
Change the power supply cord - Whirlpool Dryers
  • 5,911 Answers
The following link explains how to convert a dryer from a 3 prong power cord configuration to a 4 prong and vice versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
NOTE: The instructions are for United States standard wire code. If this is not what you were asking for, or if you live in a country other than the US, please post back and let me know. I hope this helps you.
Posted on Jun 24, 2009
No power light on my power button at all
More than Likely your problem lies in your power supply, but could also be your G plug power cable. I would first replace the power cord to see if that solves your issue, if it does not then more than likely its your power supply. Try changing the power cord and get back with me if that dont work and I will gladly walk you thru replacing your power supply.
Dec 26, 2013 | Dell XPS 420 PC Desktop
Change power supply
Are you refering to the AC jack? Have you tried another Cord/charger of the EXACT same power specs? Has the AC jack been damager due to pulling on the cord? HP Support may help: http://h10025.www1.hp.com/ewfrf/wc/product?product=3650971&lc=en&cc=us&dlc=en&lang=en&tmp_track_link=ot_we/prodlink/en_us/3650971/loc:0&cc=us
Feb 11, 2013 | HP Pavilion dv9700t Notebook PC
I need a power supply for atari 7800
the Sega Genesis model 1 power cord is the same voltage and amps as a 7800, if you know how to solder you can change the power port and use that power cord. or you can just hard wire a power cord on here is the site for that . http://saundby.com/atari7800mod/7800_powermod.html
Apr 14, 2012 | Atari 7800 Console
It wont turned on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Mar 21, 2012 | Lexmark X2500 All-In-One Printer
Tv did not turn on
Look at the power supply to see if anyhting burnt, fuse, bad capacitors. I doubt that the power cord is bad, the same size fuse should be used as the original one.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
Cause for error code sc560 on ricoh ap3850c
H there below is what is stated in the service manual and I suggest to change the power cord before the main PSU (Power Supply Unit)
SC 560 Zero Cross Error
When the power switch is turned on. The machine checks how many Zero-cross signals are generated during 500 ms. If the number of Zero-cross signals is more than 66 or less than 45 and the condition is detected more than 10 times this code is shown.
Cause is electrical noise in the supply from the power cord.
Solution
  • Change to another power wall socket
  • Change power cord
  • Replace main PSU (Power Supply Unit)
I hope this help you
Thanks J
Jan 12, 2008 | Ricoh Aficio AP3800C Laser Printer
Problem in power supply
you changed the cord or the power supply?
Oct 23, 2007 | HP LaserJet 1320 Printer
Dryers Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
