Hi you press the sync button on the remote and the sync button on the Wii console near the memory card reader. Hope you get sorted :)
On your wii console there should be a little opening panel on the front, which has a SD card slot, and a red rectangle button. On the back of your wii remote if you take off the battery cover there will also be a little red circle button.
1. Turn your wii concole on
2a. At the same time, you must press and hold the red button on the console, and the red button on your wii remote. Hold for 5 seconds.
2b. If 2a is too frustrating to do, press and hold the console red button first, and while you keep holding, press and hold the controller red button (just make sure you don't press the remote first). Hold for 5 seconds.
3. When you have released your finger from the red button on both the console and the controller, give it a few seconds and your controller will flash and then reset to a player position.
if this does not work, just redo this again but hold for longer.
There is red button inside the battery compartment of each controller, and one inside the front flap under the disc slot, you need to press both together while the console and controller is on and it should then work. Good luck!
Step by step instructions on how to sync the Wii Remote or Wii Remote Plus to the Wii console using Standard Mode.
Note:
Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
What to Do:
SOURCE: nintendo wii not powering on and remote blinking
Just talked with Nintendo about this matter. Fortunately, the Wii has a safety feature on the AC adapter which shuts it down should there be any sort of significant "spike" or interruption with the power. The solution? Unplug the AC adapter for about 2 minutes (from the wall and the Wii unit itself), then plug everything back in! Believe it or not, this actually works!
SOURCE: Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
SOURCE: remote disconnection.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
129
SOURCE: my wireless nunchuck wont sync with my remote whats wrong
Return the product and use the Nintendo wired nunchuck. The nintendo wired product is only 19.99 and the cord is not that bad of a deal.
SOURCE: How do you connect a second wii remote?
If the controller is sync'd and showing the light. Then all you have to do is select how many players. I would recommend calling Nintendo or their website to step you through this . :)
