Question about Konica Minolta magicolor 2400 Laser Printer
Requests new cyan toner...error light flashes 1 sec intervals
Replaced w/new cyan- still error light - replaced PB Sw Assemb - Cartridges are full and KM Official...cleaned everyrthing - no luck. help.
I'm having the same problem with both 2400 and 2500 printers so I did the same to both...still not working.
  • Anonymous Mar 16, 2014
    KM C224 error code p6, p21, p28 cyan color is very light at one end and registration is not proper
  • 32 Answers
The toner carridge is stightly out of rotation, if you manually turn the carridge 2 notches this will reset itself when you close the cover.
si
Posted on Jun 26, 2009
Brother dcp9040 cn . you had advised me before. replaced toner cartridges. continue to say load cyan toner. had reordered a new cyan toner and replaced it. removed drum . it still contiue to say load cyan...
Try reseting the toner cartridge via the operations panel.
Do this by opening front door and pressing clear/back button, a menu will appear, we want to select C-TNR-S or C-TNR-H depending on if you are using Cyan/TonerStandard or Cyan/Toner/High Capacity, so use arrows to go to correct one then press ok to select it, then a new menu appears, we want to select 1 and ok to reset, then it should just go back to cover open.
That should do it, have you tried it? as I think I told you the same before, I also need to know if you are using original brother branded toners or refill/remanufactured ones. You can reach me via this question
Steve
Jan 21, 2012 | Office Equipment & Supplies
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
Using the same cartridges for the HL-4070CDW, I refilled the black yellow cyan and magenta cartridges. when I put them all back into the printer, the RED toner life end comes on saying that cyan, magenta,...
There's a window on each end of the cartridges and light shines thru to show when they're empty, your refill toner may not be the right density. If you put a small piece of electrical tape over the windows on the cartridge, the error will go away, but you have to watch print quality to change or add toner.
Aug 11, 2009 | Brother HL-4070CDW Printer
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Error flashing, Status 'Put Cyan Toner' - but toner showing 100%
I think someone touched on this solution briefly, but here is how you fix the problem.
Clean the 3 copper contacts on on the green chip with an eraser or rubbing alcohol. The chip is on the right side of the cartridge. You will probably see black lines on the contacts. This will fix the issue about 90% of the time.
If it doesn't work you want to clean the chip reader. This is the switch that CCSStech was talking about. It also sits on the right side of the printer almost under the toner cartridges and has three prongs sticking up. Clean those prongs with alcohol. If that doesn't work replace the switch. If you are using refilled cartridges, the chip on those sometimes doesn't work. In that case have the manufacture of the refill replace the toner for you.
Feb 21, 2008 | Minolta magicolor 2400W Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
246 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
