Question about Samsung PCN5425R 54" Rear Projection Television
Sp42 hi ive recentley had my samsung rear projection repaired but now the picture is missing the right hand side (all black for bout an inch) im told i need to set this via remote but dont know how as i have no service manual can you help kind
  • Samsung Master
  • 8,617 Answers
You can get the servic manual emailed to you from this link.
Posted on Apr 05, 2008
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Problems with the picture
my samsung rear projection tv was nocked no it has a 4 inch vertical bad on the left hand side from top to bottom whats causing this
Feb 27, 2010 | Samsung Televison & Video
Samsung tv picture moved to right hand side
The remote should a format or zoom type button. If all fails get the owners manual or if 'BOX' remote call that company and ask were fomat type button is on the remote.
Good Luck, Big Irish.
Nov 22, 2009 | Sony KP-61HS10 61" Rear Projection...
Samsung HLP5063W 50" DLP Projection TV has a 3 inch black band
Did you check the picture format and adjust for 16:9 in the menu?
Jan 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung HLN617W Screen Moved Up
Yes, you can repair it yourself. All you need is solder, solder wick, a capacitor checker rated at more than 1000uf and a screw driver.First, remove rear cover and locate vert. circuit. Check all 100uf capacitors around vertical output. Unsoldering one leg to remove from circuit so as to get a good reading. Replace leaky ones with equal value. Another possible cause for that is the convergence board. If you have colored shadows around the screen there is a small board up above main p.c.b. Simply replace it. Another thing to try is to access svc. menu and write down value of vert. hgt. Then change it back and forth to see if it is adjustable. this may be an easy, or difficult fix. Good luck, Russmann.
Jun 12, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
Sky 42 inch plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 06, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
