Question about Sony MDS-JE520 Mini Disc Player
I have a Sony MDS JE520 mini disc deck. How do I
I have a Sony MDS JE520 mini disc deck. How do I copy music to my PC? I have a Dell Inspiron 1505 with Windows Vista.
    President:
  • 1,285 Answers
Requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Posted on Jun 28, 2009
On the back of the mini disc player put the phono leads,(red and white) in the out connections.Attach this to the mic input on your pc.Open the sound recorder on windows and play it through. Be careful to use the auto pause feature on your mini disc so as it doesn't make one long track of all your songs. To go direct with a usb you can only do it using ESDL (ELECTRONIC SOUND LABORATORY) mini disc drive which costs £3,000.This is used by journalists and crime scene investigators, hence the price. If you manage to put them on your pc you still might not be able to burn them on to a cd.They're a different format. wmcdrum.
Posted on Jul 13, 2009
How do I reset my Sony mini disk MDS-JE520.
What does "reset" mean? Do you mean the Setup menu?
Sep 29, 2014 | Sony MDS-JE520 Mini Disc Player
Display showing C13-disc error, continually
Your deck cannot read the table of contents on the MD, you may have the disc shutter locked, you may have a bad disc, you may need to reformat the disc before it will record or it may be dirty or the deck is not level or the disc is bad (whew), tye another disc...
Mar 08, 2011 | Sony MDS-JE520 Mini Disc Player
MDS JE520 Disc stuck in unit Toc light on. Previous to this state C13 error flashing.
the C13 is a mechanism error. The TOC means Table of Contents which is the part of the disk that determines the beginning of each track. These units are somewhat delicate and not really DIY repair candidates. Parts are still available for these. Look for either an authorized Sony service center or at least a shop that has worked on these in the past for repair assistance. The loading mechanism may need to be repaired or replaced.
Dan
Feb 03, 2011 | Sony MDS-JE520 Mini Disc Player
Sony MDS-JE520 Mini Disc Machine no operation, standby led is illuminated, but pressing on/off button it does not respond
This is from my own experiance. I inadvertedly bent the cover of my deck and had the same error.
The minidisc is blocked in the loading mechanism. Too much weight on top of the deck can bend the cover and the metal support which is above the loading sledge. The slider is then blocked. When you connect the power you can hear a motor trying to move for as short instant.
Disconnect the deck from the power supply.
Take of the cover and check if the support is bent. carefully bend it upwards, if so. Reconnect power and check if the deck powers up..
That's my solution which worked for me.
BTW I second Obertellis advice to find a MDS-JE780 (or MDS-JB980) they are the most complete decks ever made by Sony
Jul 25, 2010 | Sony MDS-JE520 Mini Disc Player
WHERE CAN i BUY A REMOTE TO WORK WITH MDS-JE520
Hi, you can go to any sony shop around you or visit their site and check for the contact address to get the remote.
Take care.
May 18, 2010 | Sony MDS-JE520 Mini Disc Player
Sony mds-je520 on stand by led on bur cant tern on player
Make sure the "TIMER" "Rec"/"off"/"Play" switch is set to "OFF".
Then press power, and you should be in business as soon as it read the TOC on the disc. Without any disc inserted, it should go straight to being ready.
Apr 27, 2010 | Sony MDS-JE520 Mini Disc Player
Strange recording problem - no diagnostic messages
Sounds like the servo is shot on the deck that moves the laser. MDS JE520 is a nice early deck 1998-1999 vintage, so it's had a great run and I'd look for another on eBay or at a "hamfest" swap & shop for parts.
Mar 26, 2010 | Sony MDS-JE520 Mini Disc Player
I have a Sony MDS-JE520, NO SOUND!! but the rest seems to work
stick it up your *** 3 times and it will do the trick :D
Mar 20, 2009 | Sony MDS-JE520 Mini Disc Player
Sony MDS-JE520 Mini Disc Player Logo
862 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
