Fujitsu Halcyon ASU9RMLQ Mini Split Wall Mounted Heat Pump Indoor Unit - 9,00 Logo
A
Anonymous Posted on May 18, 2014
Red operation light means what on Model ASU9RMLQ & ASU12RMLQ?
Unit will not cool the room. Batteries changed. The red light stays on for operation, is that correct? The filters are clean/
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Mar 15, 2008
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Donni Steen
  • 687 Answers
  • Posted on Mar 21, 2009
SOURCE: Unit will not operate
http://www.fujitsu-general.com/global/products/index.html
Find your manual and check the code of the blinking green light. It will give you the resolution for your code. If you still have issues, post a comment back on this thread and I will be able to help you. You will need your model number for the website.
Anonymous
  • 6 Answers
  • Posted on Aug 13, 2010
SOURCE: Ihave a fujitsu air conditioner
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Dec 21, 2010
SOURCE: I HAVE A MODEL ASU9RMLQ
It's actually error code E-2
E-=2...... (Thermostate sensor)This error means that theunit has gone into a protection mode.
Coil sensor defective. Replace it.
Anonymous
  • 32281 Answers
  • Posted on Jan 30, 2012
SOURCE: Fujitsu. Wall mount AC inverter. Operation ,timer,and economy lights all blink, I clean the filters but no change , unit is only 3 months old..
Your AC unit should be still covered by warranty, get the installer to check you AC unit.
Lights flashing on the inside unit Futitsu Split System during operation. What do they mean?
Called Flash Codes. First try turning off everything at the breaker for at least 2 hours and preferably overnight. Turn back on and wait 15 minutes for self test to complete.
https://www.orionair.co.uk/PDF/fujitsu-trouble-shooting.pdf
Red "check" light comes on and stays on when trying to charge scooter. Charger and scooter are old-purchased second hand, but batteries are new. What does the red light mean?
hi have got a make & model of scooter and the red light u refer to is it on the scooter or the charger............cheers
I borrowed a portable a/c unit Comfort -Aire model number PD121-5 cant get it 2 stay on cool it has timer & changes temp all the time. can anyone tell me how to reset this thing? No remote
some ac units portable or other wise use a program where it starts on full cool and as the humidity is removed from the room the program changes to less cool or switches off for periods ( called comfort mode on some units and is used for sleeping where the room temp is maintained and does't get colder as the night goes on)
try and down load a operators manual from the net
1helpful
There is a flashing red light below on the left side of my firebox
THAT FLASHING RED LIGHT IS PROBABLY THE RECIEVER FOR YOUR REMOTE CONTROL & EITHER IT'S SIGNALING PROPER OPERATION, OR YOUR BATTERIES AT FIREPLACE RECIEVER ARE LOW, & SOON THE REMOTE WILL NOT OPERATE IT AT ALL. CHECK THE BATTERIES!
What would cause the red light to stay on all the time. This is killing my batteries
Steve-
I have reviewed the on-line installation information for the DL2700 and I do not see your particular scenario listed (red LED staying on). Here is the website link:
www.alarmlock.com/
I therefore suggest that you call Alarm Lock (the manufacturer) directly with your problem for their assistance. The number is 1-800-252-5625. They are located in New York, so you will probably want to call during East-coast business hours. Be sure and have any model number and purchase date info on hand when you call.
I HAVE A MODEL ASU9RMLQ AND ON FAN THE FAN STARTS THEN AFTER 15 SEC. IT QUITS AND FLASHES OPERATION
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Top Fujitsu Heating & Cooling Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
