Question about Baby Gear
Overinflated innertubes Could you please tell me where is the best/cheapest place 2 get Britax3 inner tubes from? I have over inflated those on my daughters stroller ! I need one size 12.1/2 x 2.1/4 & one size 10x2.0 I would appreciate any advice... please help!
  • 71 Answers
Ry performance bicycle(the cheapo bike shop!) and also their website. they may have the size tube you are looking for. You can get a pricematch on any item also.
Good Luck!
Posted on Jun 24, 2009
Tire pressure says sensor fault it's a 2009 Mercury mariner do I need to replace or can it be reset
The "tire pressure sensor fault" message is an indication that there is a problem with the tire pressure monitoring system (TPMS). A tire pressure monitoring system is required for all motor vehicles manufactured after 2007. The pressurized air inside the tire is monitored by the TPMS. The TPMS consists of tire pressure sensors which are placed inside each wheel. These sensors provide the driver with information regarding the actual tire pressure of each tire in real time.
All car tires are tubeless, unlike bike tires that have an inner tube that when filled with air inflates the rubber tire. Tubeless car tires have an inner core that is filled with pressurized air. The tire should be filled based on the manufacturer's specified PSI. This can usually be found on a sticker on the driver's side door or trunk. If the tire is overinflated or underinflated, this could cause damage to the tire and/or hazardous driving conditions.
Problems that are possible when a tire is overinflated:
  • Shorter lifespan of the tire
  • Broken tire belt
  • Uneven wear on the tread
  • Bad traction-specifically in the rain and snow
  • Difficult to steer and/or maneuver (it may feel as if you are driving on ice)
  • Decreased friction
  • Driver may experience a harsh ride
  • Could cause damage to the suspension
  • Tire may blowout/explode
Problems that are possible when a tire is underinflated:
  • Make cause the tread to separate
  • Premature wear on the tread
  • Decreased fuel economy
  • Difficult to steer and/or maneuver (it may feel harder to turn with precision)
  • Increased friction
Oct 28, 2017 | Mercury Cars & Trucks
How to change back innertube on 26" mongoose estes bike
First turn the adjuster on the rear brake handle all the way in and make sure the slots on the adjuster and set nut are lined up, pull the brake cable out and leave it attached to the lever to open the rear brake pads, loosen the bolts on the tire and pull the derailer up to remove the tire, remove the dustcap from tube and using a flat tool (Wal-Mart has tire tools for $1) take one side of the tire bead out of the rim, pull the old tube out, place the stem of the new tube in the hole and put the cap on, tuck the new tube in the tire trying to keep it flat as possible, push the bead of the tire back into the rim. before inflating the tire, put it back on the frame while pulling the derailer up to get the chain back on the cogs( they will adjust later) tighten the bolts and inflate the tire to desired pressure (between 35-60 psi)
Jul 05, 2014 | Mongoose Cycling
How to remove back wheel from the frame to replace the inner tube on a Schwinn Sierra bike
to change the innertube you have to get something flat and put on in the tire and move the tire around tell it pops open
Apr 20, 2011 | Cycling
I need the inner tubes for the Peg Perego Skate model,2 tubes. Where i can find this???
You can go to Amazon.com and buy the 10" X 2" innertube and it works like a charm. I too tried forever to find the exact fit, but ended up going to the next closest size.
Be careful not to pinch the innertube when installing because it will cause a leak so I recommend a person that has done it once or twice.
Nov 19, 2010 | Peg Perego Skate Bubbles Standard Stroller
How do you change a innertube on a back wheel of a mountain bike
You have to remove the entire wheel from the bike. Then change it just like you'd change a front tire... remove oneside of the tire from the rim, pull out bad tube, clean rim, put in new tube, put tire back on rim, inflat tube... good to go. There are 1,000,000 videos on YouTube to show you this process.
Nov 08, 2009 | Bike Extreme Lite Youth Shoulder Pad
Any tips on putting a new inner tube into the tire
If you have had a puncture check the inside of tire for likely causes of puncture (nails tacks etc THORNS if moutain biking in the countryside. Make sure the inner liner is o.k. partially inflate the innertube. Line up the valve with the hole in rim gently insert the tube into the tyre working from either side of the valve . Check that the innertube is not pinching as you press tyre into position again working both ways from the valve. Squeeze the tyre between hand and fingers to ensure the it is properly positioned, inflate and off you go.
Sep 19, 2009 | Pit Cycling
Hello, Our Jane Powertwin buggy has 3 flat tyres - they go down when inflated. From where can we buy new inner tubes please
You can get inner tubes at any bike store you just tell them what size they have all of them.
Jun 27, 2009 | Jane Powertwin Jogger
Left wheel deflates when trying to inflate it!
You can purchase a replacement innertube from a bicycle shop ( I believe that this is a 12" tube) - try to get a tube with a bent valve as this helps a lot when inflating. If you contact www.bugaboo.com you can also buy one through them.
I hope this helps.
Mar 15, 2009 | Bugaboo Frog - Black Stroller
We bought a Schwinn 12'' Roadster the end of November for our Granddaughter. One of the rear innertubes exploded, and we have been to 6 stores, including 2 Schwinn, and researched online, and cannot find a...
Just found the 10x2 tubes here. I am going to order today. I will let you know if I have any problems getting them from this supplier.
http://www.racemotorparts.com/products.php?id=1329
Mar 03, 2009 | Schwinn 12" Roadster Tricycle
Phil & Teds Sport
It sounds like one of a couple possible problems:
*Perhaps the tires have been overinflated previously and have edged out of the rim. In that case, the all the air will need to be let out of the tires, the edges of the tires edged back into the rim and then the tires inflated to slightly below the maximum pressure.
*You indicated that it was new, so the suggestion above may not apply. If you used the gauge at the garage that is connected to the air supply, it is likely not calibrated proper and the tires are, in fact, overinflated - in which case the first suggestion should be followed.
*If it's not one of the first two and the stroller is in fact new, then you should return it and ask for a replacement. There is a third possible problem . . .
*If the stroller has been stored in the heat, it's possible that tubes may have "stuck" to the tires internally and are placing pressure unevenly. You can tell if the tires have tubes by letting the air out and pressing on the valve stems. If they move in, which they probably will, then there are tubes. If you can remove the valves from within the stem and evacuate all the air, the tubes may adjust and you can reinstall the valves into the stems and air the tires up again.
Jul 18, 2008 | Phil & Teds E3 Jogger
Baby Gear Logo
59 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
